Old 6th June 2006, 11:34 AM   (permalink)
Experienced Member
sram has a little shameless behaviour in the past
Default Make external hard drives usb powered
Hello folks. You know that external hard drives are good/easy way to gain additional capacity with no much hassle. All of course require power, but some require more power than others. It is even more convenient when they are USB powered, especially if one intends to use them with laptops.
Maybe you've already guessed where am I going!! Is it possible to make drives that use a power adapter work with only USB!?? Perhaps by using more than one USB port to get more current?
Does the voltage differ?
Are there USB powered hubs that will enable to get the matching power I need (This will only work for desktops though, it is meaningless for laptops)
It will be neat if it is achievable!
Discuss away, thanks.
sram is offline   Reply With Quote
Old 6th June 2006, 11:56 AM   (permalink)
Experienced Member
ParkingLotLust is on a distinguished road
Send a message via ICQ to ParkingLotLust Send a message via MSN to ParkingLotLust
Only problem is that hard drives need +12v and +5v while (pretty sure laptop drives only need +5v) the USB port only supplies +5v at a MAXIMUM 400-500mA. And to get that current, drivers have to request it. So maybe if you used a couple of usb ports through a charge-pump converter or something to boost the voltage, then maybe it's possible.
ParkingLotLust is offline   Reply With Quote
Old 6th June 2006, 01:06 PM   (permalink)
Experienced Member
Your reply raises this question in my mind. Does all external hard drives that come with power adaptor uses 12 volts? There are slim ones which I think only uses +5 volts.
Old 6th June 2006, 01:07 PM   (permalink)
Experienced Member
justDIY is a jewel in the roughjustDIY is a jewel in the rough
you should be able to sneak one or two amps out of a motherboard usb port, but that won't likely be enough to run through a boost converter and get enough power at 12v to spin a desktop hard drive
stick with notebook drives, or mod your case to provide a DC power jack for your hard drive.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline   Reply With Quote
Old 6th June 2006, 01:08 PM   (permalink)
Experienced Member
suicidalmonkey is on a distinguished road
USB powered Hard Drives are already manufactured.
They are commonly known as pocket drives.
Here is a link to a shop that sells them in Australia.
http://www.dse.com.au/cgi-bin/dse.st...ct/View/XH8253
If your looking for information on how you can build one yourself, sorry, but I can't help.
suicidalmonkey is offline   Reply With Quote
Old 6th June 2006, 01:10 PM   (permalink)
Experienced Member
oh i should add ... the 500ma thing is part of the usb 2.0 spec, aka usb high speed (not usb 2.0 aka usb ultraspeed or whatever they're calling it now).
so, knowing that not every system out there will be usb 2.0 compliant, most external drives, even the slim ones with notebook hdds inside them, ship designed for external power. if your systems are all usb 2.0, then you should be able to make a second usb cable with an ordinary power jack on the other end ... so one cable for power, one cable for data... or you could hack open your drive enclosure and jumper the power wires inside
Favorite numbers:
Old 6th June 2006, 03:39 PM   (permalink)
Experienced Member
Someone Electro is on a distinguished road
Send a message via AIM to Someone Electro Send a message via MSN to Someone Electro Send a message via Yahoo to Someone Electro
USB is curent limited so no way of pulling more out of it.
If your pc has a game port you can use that.Its not curent limited so will suply a lot,but also be careful becuse shorting this can result in damage since you short the PSU over a thin track on the PCB.
Il give you shocking experience.
Someone Electro is offline   Reply With Quote
Old 6th June 2006, 05:28 PM   (permalink)
Experienced Member
evandude is just really niceevandude is just really niceevandude is just really nice
http://www.newegg.com/Product/ShowIm...ure+%2D+Retail
There's an example of an external enclosure for laptop drives that uses two USB ports to get enough power. As others suggested, nothing really special except for paralleling the power wires of the two ports, and clearly it's something common and commercially available.
It's not done for 3.5" (desktop) hard drives because they use so much power... for example, a 40GB IDE desktop hard drive from western digital is specified as using 7.5 watts during read/write operations. Since it needs +12v in addition to +5v, that means you also need a DC-DC converter, which introduces some amount of inefficiency, and you probably have to have some more power head room just in case, so in the end you're probably looking at over 10 watts at least. 500mA at 5v from a USB port is 2.5 watts, so at the minimum you would need probably 4 USB ports just to power it... And worse, many of the larger and better drives are rated at around 10 watts for read/write, so you might need 5 or 6 USB ports for those. at that point, running cords to that many USB ports (as well as giving up that many ports that could be used for other devices) would surely be less desirable than a power adapter.
EEgeek.net
evandude is offline   Reply With Quote
Old 6th June 2006, 05:59 PM   (permalink)
Experienced Member
The Mad Professor is on a distinguished road
With the prices of solid state memory dropping as they are, coupled with improvements to the lithography process , going digital is looking more attractive. Thumb-drives with a four Gig capacity are now available.
It may seem like a good idea at the time , but never stir your cold coffee with a soldering iron.
The Mad Professor is offline   Reply With Quote
Old 6th June 2006, 06:19 PM   (permalink)
Experienced Member
don't underestimate the electrical load of a flash drive either, however ... I have a flash drive that will only work on self-powered hubs or direct to the motherboard ... try to run it off a passive hub (like the one in my keyboard) and I get a device exceeds bus power error or some such
Favorite numbers:
Old 6th June 2006, 09:20 PM   (permalink)
Experienced Member
hmm , what about using the USB supply to charge a small battery pack or large value capacitor located local to hardware and use the stored energy to supplement the devices power requirements under load conditions.
Old 6th June 2006, 11:25 PM   (permalink)
Experienced Member
well sure, but you still have a 2.5 watt/hour maximum charge rate ... if you're running a drive that takes an average of 5 watt/hour worth of power, you'll need a decent battery to get good runtime, and it will take forever to recharge
look at firewire enclosures ... the firewire bus supplies a lot more power, but it's not common on peecees
Favorite numbers:
Old 7th June 2006, 09:09 AM   (permalink)
Experienced Member
Dr.EM is on a distinguished road
Send a message via MSN to Dr.EM
We always get that "low power" notice for USB at college in thier macs. There are only 3 sockets on the back, and all are used all the time. It seems that the USB MIDI keyboard uses less power than the little memory sticks, so we usually connect that to the keyboard USB socket so theres a free motherboard USB for the memory sticks.
Firewire is usually found on the soundcard for PC, I have one because I have a decent soundcard. I think some more recent motherboards have them built on too.
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline   Reply With Quote
Old 7th June 2006, 10:15 AM   (permalink)
Super Moderator
Seems a strange place to have Firewire?, on a sound card?.
As you say, some modern motherboards have Firewire, or you can easily buy Firewire cards. I've recently added Firewire to my computer (as I needed to download video from a Mini-DV camcorder - the video of my daughters gig).
As I had no free slots I had to remove an extra USB card I had, so I bought a Belkin combined Firewire/USB 2.0 card - with three of each, and it came with a Firewire cable as well. Very pleased with it, dropped straight in, and worked immediately, no drivers required under XP.
Old 7th June 2006, 02:14 PM   (permalink)
Experienced Member
Blueteeth is on a distinguished road
Not sure if this is what you're after..
http://www.rapidonline.com/productin...moduleno=72282
They're avaiable from a few companies, you simply provide the HD and a USB cable. It says 'self powered' but even if it had a 5v-12V converter, I can't see USB 2.0 providing enough current for it. Plus...buying a 'kit' takes all the fun out of designing your own
Blueteeth
Inconsistency is the key to flexibility!
Blueteeth is offline   Reply With Quote
