Old 24th May 2006, 10:26 PM   #1
Default car alarm - central locking
I have a alarm installed in my car, wich when activated outputs a ( negative 12v max current 100mA )
and just installed central locking, wich has two 12v negative inputs ( one for locking , and the other for unlocking )
I need to connect them togeter so when i activate the alarm the doors will lock automaticaly, and when i disactivate the doors will unlock ....
the bigest problem is that :
the central locking only needs a 1second puls to lock/unlock ....
u guess i need some 555timers and some relays....
please help
Cell is offline
Old 24th May 2006, 11:54 PM   #2
Is this for a BMW by any chance?
Doug
douglee25 is offline
Old 25th May 2006, 12:00 AM   #3
no, its a peugeot 306, i also instaled the alarm like 2 years ago it has no extras, preety simple car
Cell is offline
Old 25th May 2006, 12:11 AM   #4
Go about it the same way I did my BMW. I believe BMW is 12+ but you get the idea. I'm not a 100% sure but Peugeot may even have a double lock feature. For the double lock feature, scroll down further. I used relays as well. Check out these sites...
http://home.att.net/~voerman/
http://www.understeer.com/doublelock.shtml
Doug
Old 25th May 2006, 12:50 AM   #5
the problem is, that my alarm has only 1 output (-12v) , wich is designed to connect an LED and place it on the dushboard ( so that when it's armed the LED lights up , and when disarmed turns off. i'm trying to use that -12v signal to conect to the central locking, some how.... i need to build some sort of circuit wich will triger a 1second pulse when the -12v signal ( from the alarm ) is sent, and a 1sec pulse when the -12 signal is shut off...
please find attached drawing
Cell is offline
Old 25th May 2006, 02:50 AM   #6
i need to build 2 Monostable circuits, but not sure if they will work, as i'm not going to give them pulses, but a fixed 12v ..... will it still work ? or the 12v supply needs to be shut off for the circuit to start the timing ??
Cell is offline
Old 25th May 2006, 03:57 AM   #7
use interface relay between alarm and to centrl lock.
mpj111 is offline
Old 25th May 2006, 12:03 PM   #8
hello,
i need a types of thermocouples, please help me , i shall wait
usmankhan is offline
Old 25th May 2006, 12:11 PM   #9
hello,
i need a circuit diagram of wireless speakers so please help me
thanks
Old 25th May 2006, 06:58 PM   #10
ok i need relay's but i cant give a continues 12v supply ! that will burn the central locking, i only need a -12v pulse of 1second .... understand ?
Cell is offline
Old 25th May 2006, 07:21 PM   #11
Your alarm should be able to vary the output time for any signal used. Doesn't your alarm work the same?
Doug
Old 26th May 2006, 12:19 AM   #12
no,
i have a piranha alarm, and dose not have any output connection
in fact i'm going to use the ( -12v LED signal out ) wich is desiged to connect the warning LED. it turns on (-12v) as soon as i arm the alarm, and turns off (0v) when i disarm it.
when its turned on, it outputs a continuous -12v supply ..... and i need only a pulse of 1second not a continuous supply
is there some kind of timer that when trigered with a constant supply it outputs a short pulse ??
Cell is offline
Old 26th May 2006, 06:39 AM   #13
Now I see your problem. I would say buy a new alarm. By the time you're done buying relays or timers, etc, you've already exceeded the cost of a new alarm.
Doug
alarm, car, central, locking
