| | LinkBack (1) | Thread Tools | Display Modes |
| | (permalink) | |||
__________________ Uncle $crooge | ||||
| | (permalink) | ||
*Can i shield the wires or shield the motors with the alluminium foil to avoid the interference as i mentioned before? | |||
Use shielded cable like is used to connect stereo components together (cut off the RCA connectors) to connect to the tank.
| | (permalink) | ||
Then do i still need to include the bypass capacitor? Quote:
*I need to use a diode to make to current to flow only one way, it is connected series with 2 DC motors. I was using 1N34A, but after it was turned on and off for once, the diode burned (i think) and cause open circuit. So i replace it with a 1N4001, now it works well. My question is, if i replace the 4001 woth a LED, does it use more current? | |||
| | (permalink) | ||||
Look at how much current the motors use when they work hard. Much more current than the max current ratings for the 1N34A or an LED. Don't use an LED in series, connect a current-limiting resistor in series with the LED and connect the combination to the power source of the motors to indicate when they run.
__________________ Uncle $crooge | |||||
| I've shielded the wires and the motor. I've tested using batteries which are fully charge and not fully charged (not full). When i use the lower power, my robot mower operates well, no interference. When i use the fully charged batteries, of course, the motor run faster and interference occurs. The motor should run as fast as possible for good mowing system, but the electromagnetic field produced by the motor is bigger. Can i shield the wires and the motor thicker (turn more round) to solve this? I use alluminium foil (for cooking) to shield them. | |
| Shielded cable or aluminum foil will stop the sparking of the motors from radiating electrical interference. But will do nothing for the magnetic interference.
| !!?!???!?!?!?? What should i do besides moving them far away to each other? Is there anything to remove or direct the unwanted electromagnetic field to somewhere else? | |
Hee, hee. Diesel engines? Hee, hee.
| Oh no... you're kidding right? I mean the diesel engines.. haha.. i use only AA's.. I'll try to solve it.. Anyway, you've helped me a lot, thank you very much. | |
| Hi, I've found this, but don't know whether it helps or not. I'm still reading it. Sharing is caring.. hehe.. | |
| LinkBack to this Thread: http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/21585-my-explaination.html | ||||
| Posted By | For | Type | Date | |
| Positioning systems? - Hobby, Science, Consumer Robots From Around the World | This thread | Refback | 21st May 2008 06:24 PM | |
