| | LinkBack (1) | Thread Tools | Display Modes |
| | (permalink) | ||
You asked how to make the output the opposite (inverted). Just swap the input pins of the comparator.
So the output will be inverted, right? | ||
| Thanks... Can i know, what is the input bias, offset current and voltage? All of them from the datasheet, i don't even know how to understand them. I'm going to complete my diploma coming August, but all of them are not in our syllabus. Can i learn them here?? | |
If you know how transistors work then opamps are easy to understand. The spec's change with temperature change but are stated at 25 degrees C for the LM393: 1) Input Bias Current. The base current of each input transistor. The LM393 has PNP input transistors. Typically 25nA, 250nA max. 2) Input Offset Current. The difference between the input bias current of one input transistor and the other input transistor. Typically 5nA, 50nA max. 3) Input Offset Voltage. The amount of input voltage change that is needed to make the input transistors perfectly DC balanced. Typically 1mV, 5mV max. One input is connected directly to ground through the low resistance input coil. The other input has input bias current through a 100k resistor. Use Ohm's Law to calculate the voltage across the 100k resistor. Typically 25nA x 100k= 2.5mV, 25mV max due to input bias current. The offset current and voltage changes it a little. Since the max input offset voltage spec is higher than the typical voltage difference caused by the 100k resistor then the output voltage will be backwards with some LM393 comparator ICs.
__________________ Uncle $crooge Last edited by audioguru; 2nd June 2006 at 10:08 PM. | ||
| | (permalink) | |||
| Thanks a lot!! Quote:
I'm really a newbie.. Thanks for telling me these.. | ||||
| | (permalink) | ||||
The voltage across the 100k resistor at one input is an external offset voltage that your circuit makes. Quote:
__________________ Uncle $crooge | |||||
For the rest, i think i get your point, thanks For the internal npn at the output. Is it fully saturated at 6mA of Ic? With 5V of supply and the 1K resistor, I get 5mA of Ic right? What will happen if the Ic is too high or too low?? | ||
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." | ||
| sheeet, I've done this course twice(don't ask) and what I wouldn't have given for all the tech heads to do the "difficult" questions. As it was the second time around I used to do a month in a weekend. | |
| | (permalink) | |||
| Yes.. I will replace it with a 220K. Thanks Currently i'm using this circuit with my microcontroller using different power supply (but they're common grounded), it works well. How if i want them to share a same source. Just connect them in parallel? Anything needs to be changed? *I'm using Motorola 68HC11E9 microcontroller, 4 AA batteries. | |
| Use the same power supply for both circuits. The 555 might stop working when the battery voltage drops to less than 4.5V but a Cmos 555 will work down to 1.5V.
| Nono.. i mean, i want to use the same supply for the electromagnetic field detector (LM393) and the uController together. Not the 555. i will use one supply to the 555. what is cmos 555? i'm using NE555 | |
| LinkBack to this Thread: http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/21585-my-explaination.html | ||||
| Posted By | For | Type | Date | |
| Positioning systems? - Hobby, Science, Consumer Robots From Around the World | This thread | Refback | 21st May 2008 06:24 PM | |
