Originally Posted by
dreamproject Hi,
I am trying to make a serial port spliiter where I can connect two devices to the serial port and use a slide switch to select the device to be connected. I tried this by using a two way switch to connect the ground wire to either of the serial port's (5 th PIN) depending on the position of the switch. But, my plan backfired and lost a PIC micro that was connected on one the two serial ports. Am I on the right track ??? . I would also like an Indicator LED to be powered from the DSR or CTS pin to indicate the serial port in use . Will this damage devices connected on the port. Thanks in advance.
