Old 6th May 2006, 09:40 AM   #1
Smile PWM with 555 am I ingenious or barmy ?
ok just check this schematic out for me I simulated it with elctronics workbench 5.12 and it works exept that for max and min pot after a second the simulation jams but I would say that that is a software limitation on the program. it seems that I can get a 0 % straight thru to 100 % duty cycle. the idea is to speed control a motor.
is there another way of doing it with out the transistor or have I hit the nail on the head for max duty cycle range ?
www.simonsphotography.org.uk/ - My other hobby
www.rushdenrotaract.org.uk/ - make a difference and have fun !
Never buy "Trust" products, all mine broke !!!
Thunderchild is offline
Old 6th May 2006, 10:08 AM   #2
Default Barmy
ok I just played around with diodes in the circuit and got the exact same result
Old 6th May 2006, 10:21 AM   #3
I looked at your circuit and it seems to me that you're achieving duty cycle adjustments by having a variable ON time and a fixed OFF time. This results is very low frequency when the duty is close to 100% and the PWM frequency goes up to maximum as the duty cycle drops to 0%.
There are applications when this is undesirable. The frequency can go up to where switching losses could be intolearable. Or the frequency will drop to audible levels and there will be an annoying hum from the motor.
"Having to do with Motion Control"
motion is offline
Old 6th May 2006, 11:24 AM   #4
Hmm, i've seen something similar here:
http://www.nomad.ee/micros/pwm555.html
It does work quite well, but the frequency changes by around 15% across its range.
Angry!? I'm absolutely electrolytic!
Music web page:
http://www.music-playground.net/artist/drem/
Dr.EM is offline
Old 6th May 2006, 11:46 AM   #5
there is no drastic frequency change. the total off+on time is constant becase one part of the pot is used to charge and the other to discharge. the transistor is keeping the supply cut off during discharge as if you look closely the pins that sense the voltages on the cap while it is discharging will be subject to a voltage devider that upsets the circuit and recs havoc. the result is the same as the secon circuit where diodes are used to seperate charge and discharge sections.
so the diode solution is probably best. just one question though: a diode can only work up to like 200 Hz or is this not a problem because it is all DC so no reversing and rereversing problem ?
EDIT:
ok I took a look at that other diagram you linked to. hm well yea i get how it works but why the hell reverse the dis and out pins. the result is exactly the same. especially as the output is push pull anyhow so if you need a clamp down to GND thats ok as well.
Old 6th May 2006, 12:21 PM   #6
What makes you thing diodes are limited to only 200Hz?, diodes are available that equal (or exceed) transistors.
Normal slow recovery rectifiers are only suitable for low frequencies, but that's what they are designed for - a diode (such as a 1N4148) will massively out perform a 555.
BTW, the two diode trick for adjustable mark/space is a VERY old technique, and is probably shown on some of the datasheets?
Old 6th May 2006, 12:26 PM   #7
yea i suppose it is i remembered seeing it in my school electronics book that just reproduces component datasheets. i couldn't remember hoe it was done and came up with the transistor solution first but having understood what was going on I worked out the diode solution for myself
Old 6th May 2006, 03:52 PM   #8
This is one of the best ways to do PWM with a 555, or better still a 7555.
if I know the answer.
Hero999 is offline
Old 6th May 2006, 04:01 PM   #9
The reason for using the discharge pin in that design is so the boost start system will work, as the discharge will be the inverse of the output pin in this arrangement, i'm pretty sure thats it.
Anyhow, I built that design again today, and used one of my new IRF540 MOSFETS (I wanted to test them). It works really well, and I managed to run two 12v lamps and a motor off of it with no problems, taking over 2A total. The MOSFET didn't even get warm and the scope showed good fast on and off times. I have a video if anyones interested. My power supply didn't take it (LM317 job) so I used the drill battery for power.
Music web page:
Dr.EM is offline
Old 6th May 2006, 05:11 PM   #10
let's see the video Dr em
musthave is offline
Old 6th May 2006, 05:46 PM   #11
This should work, otherwise let me know where I can email it:
http://www.savefile.com/files/1040585
Music web page:
Dr.EM is offline
Old 6th May 2006, 08:09 PM   #12
yea hero999 thats definitely a better way for one reason: as the output is charging/discharging the condenser and has a higher amp capacity there is no need for that minimum R of 1K that is to prevent the discharge TR from burning out. having looked at that Diagram I begin to wounder why the hell the discharge pin was inserted
Old 6th May 2006, 08:21 PM   #13
I am being told that the file format is not acceptable what codec did you use ?
EDIT it was a download error. please email to "thunderchild64 (at) yahoo.com"
Old 8th May 2006, 03:37 PM   #14
You should have it now.
Music web page:
Dr.EM is offline
Old 8th May 2006, 07:51 PM   #15
thanks mate
say i want to control 10-20 amps what mos do you advise. bvy the way i have never used a mos so tell me how to cenect it to the 555
555, barmy, ingenious, pwm
