Hello, I want to make a device with a plastic enclosure and an earth connection. The device needs an earth connection because it will switch mains power to loads that have an earth, for example a metal-cased fan and a pneumatic valve. My question is, what device class is it? According to the wiki for double-insulated (http://en.wikipedia.org/wiki/Double_insulated) this would be a class 0 device, but these 'will eventually disappear... in favour of Class II devices'. I could make it a class I device, with a metal chassis and earth connection, but I want to avoid this because it is heavier to ship and the enclosure is more expensive. I can't make a class II device, because these aren't allowed to have an earth connection. (Why is it that a class II device *must not* have an earth connection? What is the danger?) I see many devices around (such as common powerboards and light timers) that have a) plastic enclosure b) earth connection but they are not labelled as class II/double insulated, and they can't be be class 0 because the world would end if powerboards were phased out. What class are these? Thanks, David | |
As someone who does PAT (Portable Appliance Test) testing, there are two classes: Class I - with an earth lead. Class II - with no earth lead. Any portable appliance can be tested as either of these, note that the tests are completely different to each other!. As for a Class II device that "must not have an earth lead", it's basically quite simple, if it DID, it's then Class I and not Class II. Doesn't matter if your device has a plastic case, many Class I items do, but any exposed metal MUST be earthed, and able to withstand a 25A test current between the earth pin of the plug and the exposed metal. | |
Thanks Nigel it seems I am making a class I appliance. I have heard that unearthed, exposed metal parts are ok if they have two layers of insulation protecting them from the live bits.
| | #4 | |
If it's a class I (3 core lead) device, then ALL exposed metal must be earthed, and able to withstand the 25A test current. | ||
| appliance, class, connection, earth, enclosure, plastic |
