| | (permalink) | ||
| Connect the wires in the cable in series, then the magnetic field from the cable is increased.
sorry for my poor understanding. | ||
| | (permalink) | ||
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." | |||
the CAT 5 can drive how many watt? | ||
Wire is rated in AMPS, not in WATTS. 200mA is very low and just about any reasonable wire size can pass it.
| oh.. i found the CAT5 already, actually is CAT6 (that's what available at my place). can i connect as shown in below? just a little bit different. | |
| Your sketch is missing the current-limiting resistor that should be in series with the loop of wire. The 555 will melt without the resistor because its max current rating is only 200mA, and a loop of wire could be a dead short to it.
the 555 timer will melt!?!? i didn't know that, it is so serious!! but i will remain the 100R to limit the current, in case the wire cannot support it. since the multiple loop can increase the electromagnetic field | ||
| hi all, i'm going to do presentation with this circuit 2 weeks later. if anything goes wrong, correct me ok? The 555 timer produces a 10kHz(approximately) squarewave output at pin 3 with the combination of R1, R2 and C1. The 'antenna' will produce electromagnetic field on and off in 10kHz. the resonant frequency of the tank circuit is 10kHz. the 100K resistor creates a gain of a few hundred thousand which is so high that it probably amplifies its own noise and any noise that is around. It might even oscillate. If a 0.1uF capacitor is added to ground at pin 3 then it won't oscillate. When the signal is received then the output of the receiver should alternate between 0V and Vcc at the frequency of the input. With a 5V supply then the output's min current of only 6mA should be able to saturate good with 5mA from a 1k load. are these correct? i copied them from urs explaination. is there anything to be explained with this circuit? edit: 1. what is the purpose of the 0.01uF capacitor from pin5 to GND of the 555? 2. why the 0.1uF capacitor from pin3 to GND at the LM393 can stop it to amplify other noise and its own noise and stop oscilating? 3. what's the different between a comparator and operational amplifier? can a comparator be an op-amp and vice versa? thanks for helping.. Last edited by bananasiong; 22nd May 2006 at 03:16 AM. | |
