A few queries regarding components:
Would it be any different to use ZD0100 as the LED's (just to keep it a little cheaper)?? I can't find a SPDT 12V switch anywhere. I think I may swap the key switch with the toggle switch. That way you need to key in to test or fire. Can I use the jaycar part SM1030 (SPST)?? Do you agree I should use 2 lead acid batteries (12V)? EDIT: Would OZS2604 from http://www.ozgear.com.au/electronicp...ays_Fuses2.htm work?? All the key switched seem to be 250VAC. Or this: http://www.rsaustralia.com/cgi-bin/b...rodoid=1881276 |
(permalink) | |||
The RS one only rated at 125mA so is not suitable. The OZS2501 or OZS2600 from OZgear.com fit the the purpose. The main consideration is current rating and not voltage rating at 12V usage. One keyswitch allows key removal in either position while the other allows removal in one position only. The key is trapped in the other position. Personally I would choose this one. Quote:
L.Chung |
I thought that one wouldn't give the required current. I have only discussed it with the guy from the electronics store. Maybe he was trying to sell me extra. Do you think it is unnecessary.
What rating wire do I need?? I have been looking at ribbon type as it is the only stuff I can find with more than 10 cores. I will nee something like that so I can run out ignighters in groups of 10. Also, I think I will use spring connectors like in "100-in-one" kits as my connectors. Jaycar don't sell them. Dick Smith do (www.dse.com.au). There is no issue using these is there??? Thanks again for your help!! |
(permalink) | ||
For the former you have to look physically at how these guys wire up their ignitors and what knid of wires to be used. This is more commonly known as the "trick of the trade". There is some pyrotechnics forums that you can get help from too. Follow their practices and when you are good at it, you can then make changes to suit your own if necessary. Ribbon cable may be too thin to pass good current for a long distance, expensive and difficult to join together, unless you are using them in a one off situation. Looks for multi-core cable in the cable stores.
L.Chung |
CAT. NO. ZD0100
LED 3mm RED 15mcd Emmitted colour: red Lens colour: difused Wave length: 700 nm: 90 Pd W: 45nW If mA: 15 If mA (peak): 50 Min: 1.5 Vf (V) Typ: 2.0 Max: 2.8 IV Min: 3.0 MCD Typ: 5.0 Viewing Angle: 40 Are you sure this is OK?? It says peak current is 50mA. Am I reading this incorrectly. Sorry for my ignorance! |
But in the schematic, the current is only 11mA for typical LED with a 940 ohm resistor in series powered by 12V. So never could the current exceed a lot more than 11mA. Don't worry. Tell you what, in the forum if one's calculation is slightly off, there will be a lot of other users offering help to correct it. All make it better but ocasionally a not so smart guy(you *should* know by now who you are) will make it worse by offering pure bullshits.
L.Chung |
http://www.semtronics.com.au/cat/1125.pdf
I have finally found a 3 position key switch. This will allow me to have "off" (with key removed), "test" and "armed". It is, however, only rated at 2 amps. It looks to me like the test circuit is not protected by the resistor, hence it could carry more than 2Amp. Is this correct? Can I simply put the 10W resistor where S1 is, and remove S1 altogether. I would then add the 3 position switch where the 2 position switch is, with the middle position going nowhere. This would be brilliant as this will only allow the key to be removed in the "OFF" position. Can you recommend a board to put this all on?? |
(permalink) | |||
L.Chung |
http://radum.com.au/shopping/product...roducts_id=233
This is the URL of a web site selling a 20M serial cable. I am interested in using it to run between my firing panel and the fireworks. The company does not have any info on it, other than it is rated for 12V. Do you think it will cope with 1Amp for short pulses?? How much damage could this do? I don't want to use it if it will burn out before the ignightors do!!! |
For back yard firework display, there is no harm to try using it. Otherwise use a proper multi-core cable instead. Look inside electrical stores for multi-core alarm cables or even CAT5 Lan cables.
L.Chung |
Hello everybody, since I am new to this forum I will start by introducing my self. My name is Jason and I am a 20 year old EE major at Texas Tech University. I have been doing Pyro, lights and sound since my freshman year in highschool. I was the pyro guy and my high school hasn’t had pyro since I left. Every thing I know was self taught and learned by reading and experimentation.
Ok here’s my question: patrickredmon what kind of inghitors are you using? Nichrome wire or some kind of electric match or something? Thanks-Jason |
I'm using FireDragon ignightors. Not 100% sure of the difference, but I think they are electric match. They are really the only ones available to me.
I thought that cable might be a little on the thin side. Can't find any 11+ core cable anywhere!! Will have to keep looking. Don't want to buy cable that burns out, and then lose the whole show!! |
I have modified the circuit slightly. What do you think?? Basically I have moved stuff a little so that it is a tiny bit cheaper. Fewer parts per circuit.
Is this likely to cause an issue?? |
Why the 2 470 ohm resistors? you could get away with using 1 1kohm for each. It's also bad practice to use 1 resistor for many LEDs like that. You want to have a resistor for each LED. This is due to the slight differences of the LEDs when they are manufactured, one LED might draw more current than the others, which would cause it to burn out (or drastically shorten its life). You *might* be able to get away with it, but resistors are cheap.
Also, if you wire it like your schematic, the power rating of the resistors will have to be increased to atleast 1 watt. I dont see the point in having the un-armed portion if you are using the center off key switch, there really wouldnt be a difference between unarmed and off except for the green leds. but thats just my opinion, it'll work either way
Jeff Zimmerman To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. |
Usin 2 470 ohm resistors was suggested by eblc1388, although the suggestion was the I use 2 for each LED. I am a newbie to this, so I wasn't sure that it would matter. Hence the post. Thanks for the feedback. I take it that I should stick with 2 for each LED. I think the reason for 2 was incase one failed?
There is a legal requirement that there be a seperate testing circuit and firing circuit. Again, eblc1388's suggestion was slightly different to what I posted. Not sure which is better. I would love to get rid of the 'unarmed' circuit, as it would make the key switch a lot easier to get!! But I HAVE to have it. The 2 'armed' circuits was my idea - an attempt to use fewer resistors. If you think it isn't such a good idea, I will switch back to the original. I am not sure that this will draw the required 1Amp current. I was talking to a sparky today, and he was showing me some maths to calculate the current. Will this circuit pull the correct current?? |
