+ Reply to Thread
Results 1 to 4 of 4
Thread: ATX PS Spec Question
  1. #1
    savage Newbie
    Join Date
    Jun 2004
    Location
    Cape Town, South Africa
    Posts
    35
    Default ATX PS Spec Question
    I got the ATX PS specs at formfactors.org, hopefully wanting to use these power supplies and implement them properly into projects of mine.
    The spec indicates that there are 2 x +12V Rails supplied. +12V1 and +12V2. The 20/22 pin ATX connector only features the +12V1 Rail, and they do not indicate whether +12V1 or +12V2 are used in the other output connectors (HDD, Floppy, SATA, etc connectors).
    Does anyone know where the second +12V Rail (+12V2) is going to ? Either I'm blind, or the second rail is not used anywhere at any of the outputs of the power supply...
    The spec also indicates that a maximum of 11.5A is posible on the +12V2 Rail at maximum load (250W), or even better 14A on +12V2 at 400W. These are a bit high for me... Does anyone have practical experience here? Witnessed it before? I'll be rather astonished if these Power Supplies are actually capable of delivery such a high load when required...
    Thanks,
    Chris.
    Regards,
    Chris.
  2. #2
    savage Newbie
    Join Date
    Jun 2004
    Location
    Posts
    35
    Second Rail on the Aux Power Connector I was blind.
    Thanks anyways.
    Regards,
    Chris.
  3. #3
    Sebi Newbie
    Join Date
    Jan 2003
    Location
    Hungary
    Posts
    1,717
    The PC PSU without 5V loading not work properly.If You need full power from 12V out, need a hard modification.
  4. #4
    savage Newbie
    Join Date
    Jun 2004
    Location
    Posts
    35
    Yeah, I know it needs a load on the 5V Rail. I'll be using 3.3, 5 and 12.
    Regards,
    Chris.
+ Reply to Thread
Tags for this Thread
