Old 19th April 2006, 08:03 PM   #1
Default 4-digit seven segment display
how can i use a 4-digit seven segment display for displaying some data using a 2-to-4 decoder instead of transistors for the multiplexed display.
s2301931 is offline
Old 19th April 2006, 11:39 PM   #2
What do you have against the poor transistors. What did they ever do to you?
Papabravo is offline
Old 20th April 2006, 07:57 AM   #3
Default Re: 4-digit seven segment display
Assuming you have common cathode displays, you could use a 74HC139.
Design for a LED current of 6 mA and parallel the inputs and outputs since the max output current is 25 mA and you need 6 * 4 = 24 mA which is close to the 25 mA limit. So you can guard against this by paralleling the 2 sections.
Len
ljcox is offline
4digit, display, segment
