Old 19th April 2006, 02:39 PM   #1
Default Power supply voltage for LM3914
Dear All
The data sheet for the LM3914 display driver IC says supply voltage can be anything from 3v - 12v. Does this mean it would be ok to power the circuit from a 12v motorcycle battery?
I have tested it on a 3A bench power supply at 12v and it gets too hot to touch.
Trevor
Trevor Rymell is offline
Old 19th April 2006, 03:03 PM   #2
The supply voltage range is 3 - 25, so you can power the circuit from the battery. I remember that chip gets hot.
You can add a 7809 voltage regulator and some capacitors near the circuit (and not the battery).
eng1 is offline
Old 19th April 2006, 03:34 PM   #3
Hi Eng1
Thanks for the reply. Actually, I did try a 7805 with a few caps and ran that off the 12v but then the 7805 gets extremely hot while the chip remains relatively cool.
If it's ok to run it directly off a 12v supply then I can cut down on a few components.
Trevor
Old 19th April 2006, 03:45 PM   #4
Originally Posted by Trevor Rymell
Hi Eng1
the 7805 may get hot because ur droping 7V across it , also depending on the current demand
Gods own Country
Incredible !ndia
www.flickr.com/photos/_akg/
"Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime."
akg is offline
Old 19th April 2006, 04:36 PM   #5
That chip will get hot as it outputs the current for 10 LEDs and is only a DIP. I think there is usually an external resistor that sets the overall current, adjusting it could help.
Angry!? I'm absolutely electrolytic!
Music web page:
http://www.music-playground.net/artist/drem/
Dr.EM is offline
Old 20th April 2006, 02:36 AM   #6
The output transistors in an LM3914 act as the current-limiting resistors for the LEDs so of course it gets too hot if you have a high supply voltage for the LEDs, the LEDs programmed for about 20mA each and the IC set to the BAR mode where many LEDs can be on at the same time. The LED outputs have current-regulation so just calculate the value of a power rersistor to add in series with the LED supply to handle the heat.
I put a 10 ohm/1W resistor in series with the LED supply in my project:
http://www.electronics-lab.com/proje...009/index.html
audioguru is online now
Old 20th April 2006, 10:29 AM   #7
Default LM3914
Audioguru,
Many thanks for the replies. I'm nearing completion of the fuel gauge project you helped me with some time ago and I'm just now trying to see what other functionality I can add while I'm at it.
One thing I'd like to have is a "low fuel" warning. The LM3914 has an alarm function where you can cause one LED out of the 10 and all those above it to flash when the appropriate input signal is applied.
Is there anyway to make this work the other way around ie the selected LED and all those below it to flash? Just an idea.
Thanks again.
By the way, very nice sound level projectand excellent write up. Very neat construction.
Trevor
Old 20th April 2006, 02:43 PM   #8
Hi Trevor,
Thanks for the comments about my project.
The LM3914 and LM3915 don't light any LEDs at a low reading which would cause no voltage across a resistor feeding the LEDs, which can turn off a transistor which will make a low fuel alarm.
Old 20th April 2006, 03:33 PM   #9
Default LM3914
Audioguru
Thanks so much. I should have thought of that. I was fixated on trying to turn something ON instead of OFF.
Many thanks for the assistance and patience.
Trevor
lm3914, power, supply, voltage
