Old 18th April 2006, 08:34 PM   (permalink)
Default Infrared Reciver
Hi guys. I wan't to ask you all, if it possible to put a counter, to a schematic like these, on this following page.
http://home.cogeco.ca/~rpaisley4/IrProximity.html
Maybe a 7 segment counter like this one -
http://www.aaroncake.net/circuits/counter.htm
So my questions is, can i put a counter (on the link i gave you), on the output of the voltage comparator on the first link.
Please reply fast, is kind of emergency
CommanderKeen is offline
Old 18th April 2006, 08:46 PM   (permalink)
You can put the TSOPxxxx series to ANY counter, gate , microcontroller, transistor base....anything that accepts a 5volt logic.
docel is offline
Old 18th April 2006, 08:48 PM   (permalink)
Thanks, so it would work just find with the http://www.aaroncake.net/circuits/counter.htm
Old 18th April 2006, 09:05 PM   (permalink)
Yo!!
docel is offline
Another question is, how can make a reset button on my 74LS90 BCD Counter. ?
Old 18th April 2006, 09:09 PM   (permalink)
switch logic on pins 2 and 3, 6 and 7
docel is offline
Old 18th April 2006, 09:13 PM   (permalink)
You can leave out or ignore pin 7.
ie., 2, 3, 7 = H, H, L then op Qa to Qd = L
....and LS 90 is decade counter!
docel is offline
Old 18th April 2006, 09:16 PM   (permalink)
Thank you again, for the fast replies. I will come back when some other problems arrive
Old 18th April 2006, 09:27 PM   (permalink)
Good luck!
docel is offline
Old 19th April 2006, 01:10 PM   (permalink)
Can you help me to calculate the resistors. R1-R6.?
Can't see how he has comed to those results.
Old 19th April 2006, 01:28 PM   (permalink)
OK. Google '555 calc' you'll get a lot of pages explaining the 555 timer IC and teh calculations. Quite simple they are!
docel is offline
Old 19th April 2006, 02:52 PM   (permalink)
For a voltage comparator, would a LM339N fit well?
And why is he using 2xNe555, insted of one?
Old 19th April 2006, 05:01 PM   (permalink)
I have a problem, i coudln't get the TSOPxxxx series. So am stuck with another that runs at 36khz. So what changes is that gonna make to my schematic?
Do i have to make some changes?
Old 19th April 2006, 05:29 PM   (permalink)
Just alter the frequency of the transmitter to match, but it's not THAT critical - it probably won't be needed. Bear in mind, you're only roughly setting the frequency in the first place, calculations aren't very accurate, you need to measure and adjust it if you want accuracy.
Old 19th April 2006, 05:34 PM   (permalink)
Okay, so it will still work in some way. Even if I don't make any changes. Just not that good.
