LinkBack (1) Thread Tools Display Modes
Old 17th April 2006, 12:55 AM   1 links from elsewhere to this Post. Click to view. (permalink)
Default LM3914 Help - Battery Monitor Circuit Needed!
Hey guys,
I'm in need of an 8.4v battery monitor circuit, using a LM3914 from National. The battery is NiMH (though it shouldn't make a difference...).
Also, if I wanted to change the battery from 8.4v to 7.2v, what would I have to change on the diagram (I'm guessing some resistor values)?
How would I calculate the resistor values if I wanted the circuit to monitor a different size battery?
Thanks in advanced!
-Skyone
Skyone is offline
Old 17th April 2006, 01:56 AM   (permalink)
Default Re: LM3914 Help - Battery Monitor Circuit Needed!
Originally Posted by Skyone
Hey guys,
Thanks in advanced!
-Skyone
I just posted one on another forum for a lead-acid. The monitor had a range of 11.8 to 13.8V. I could change it for you if you tell me the range you want to cover.
Ron
Roff is online now
Old 17th April 2006, 04:49 AM   (permalink)
Atleast a 7.2v-8.4v would be awesome, maybe 7.2-9.6v, if it's not any trouble.
Thanks again!
Skyone is offline
Old 17th April 2006, 03:03 PM   (permalink)
Thanks again!
Do you mean you want it to be adjustable? Keep in mind that the high end indicates fully charged, and the low end means you need to recharge.
Ron
Roff is online now
Old 17th April 2006, 10:57 PM   (permalink)
Thanks again!
It would be nice to be adjustable, yes.
Skyone is offline
Old 4th May 2006, 08:12 AM   (permalink)
Sorry for the BUMP, but I still need such a diagram. Ron, can you help?
Skyone is offline
Old 4th May 2006, 01:26 PM   (permalink)
Each fully charged cell is about 1.5V fresh from the charger. Then an 8.4V battery with 7 cells will be 10.5V.
Each discharged cell will be about 1.0V. Then a 7.2V battery with 6 cells will be 6.0V.
Do you want the voltmeter to accurately show this entire range?
audioguru is online now
Old 4th May 2006, 03:35 PM   (permalink)
Yeah, Skyone, you need to specify the adjustment range and the full-scale range(s).
Ron
Roff is online now
Old 4th May 2006, 03:40 PM   (permalink)
Ok, I need a 7 Cell (8v-10.5v) battery monitor. I have no more need for the 6 Cell 7.2v one. Does this help?
EDIT: Meaning that it doesn't need to be adjustable, just set to measure a regular 8.4 NiMH battery.
Skyone is offline
Old 4th May 2006, 04:05 PM   (permalink)
I think the schematic is on my home computer. I'll look for it when I get home.
Ron
Roff is online now
Old 4th May 2006, 11:00 PM   (permalink)
Thanks man, you guys are awesome.
Skyone is offline
Old 5th May 2006, 03:15 AM   (permalink)
Skyone, what are you going to use as a power supply for this monitor?
Ron
Roff is online now
Old 5th May 2006, 03:48 PM   (permalink)
What does the power supply's voltage have to be? I would like to use the battery I'm monitoring as a supply, with a voltage regulator to cut down the voltage to however much the 3194 needs.
Thanks!
Skyone is offline
Old 5th May 2006, 05:41 PM   (permalink)
OK, here's the schematic. I haven't tested it, or even simulated it, but I think it will work.
Ron
Roff is online now
Old 5th May 2006, 10:40 PM   (permalink)
Thanks, Ron.
The only thing I'm confused on is the TL071 (U2). What are the pins that are shown in the schematic? I'm guessing IN+, IN-, OFFSET 1 and OFFSET 2, while OFFSET 2 is attached to GND? Or is IN- attached to GND? Also, on R5, and R8 - are those linear pots?
EDIT: What do the LEDs have to be rated at, in voltage?
-Thanks!
Skyone is offline
LinkBacks (?)
LinkBack to this Thread: http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/20933-lm3914-help-battery-monitor-circuit-needed.html
Posted By For Type Date
Google INTERIA.PL - szukaj: LM3914 This thread Refback 17th May 2008 11:07 PM
