Old 3rd April 2006, 05:14 PM   #1
Default BiPolar HFE Tester
hi guys,
i'm doing some HFE tester and i need to compare the GAIN of TRANSISToR with a referce value.
any ideas how cna i do it ?
regards,
crowinu
\'It Can\'t Rain All The Time\'
crowinu is offline
Old 3rd April 2006, 06:58 PM   #2
Default Re: BiPolar HFE Tester
Originally Posted by crowinu
hi guys,
regards,
crowinu
AC hfe? DC Hfe?
At what current level(s)? What Vce level(s)?
The values you get will depend on these parameters.
Ron
Roff is online now
Old 3rd April 2006, 09:54 PM   #3
If your collector voltage is above the saturation region, the Hfe won't change much with collector voltage, so all you need is a resistor in the collector to measure the collector current and a resistor in the base circuit to measure the base current.
Russlk is offline
Old 4th April 2006, 08:06 AM   #4
Originally Posted by Ron H
hi guys,
regards,
crowinu
AC hfe? DC Hfe?
it is DC HFE
my aim is to for example set a certian GAIN value of 200 and determin if it is greater than 200 or less thne 200
crowinu is offline
Old 4th April 2006, 08:09 AM   #5
you mean i get ib and ic and then with ic/ib i get the gain ?
crowinu is offline
Old 4th April 2006, 09:06 AM   #6
yes.
Gods own Country
Incredible !ndia
www.flickr.com/photos/_akg/
"Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime."
akg is offline
Old 4th April 2006, 12:07 PM   #7
yes.
ok i undestood that, but need to do it with a microcontroller maybe i didn't explain myself right :|
crowinu is offline
Old 5th April 2006, 03:18 AM   #8
So, you need 3 or 4 A/Ds in the microcontroller to measure the base voltage, the base drive voltage, the collector voltage, and if the VCC is not fixed, a 4th A/D to measure VCC. Alternativly, you could use one A/D and switch the inputs.
Russlk is offline
Old 6th April 2006, 03:37 PM   #9
what do you mean by base drive voltage ? and is it worth it to change VCC or just keep it fixed ?
crowinu is offline
Old 6th April 2006, 03:45 PM   #10
The classic way to measure gain is to measure only ONE parameter, the collector current. For your purposes it would be easier to measure the collector voltage, you can then easily calculate the current and hence the gain.
The technique is to feed the base from a constant current source, no need to measure it as you already know what it is.
So historically, you would feed the base via a constant current source, and have a milliammeter in the collector, by suitable selection of the constant base current and meter range, you can read the current gain directly off the analogue meter scale.
There are obviously far more complicated methods, but this is simple, easy to do, and should do all you need?.
Old 7th April 2006, 12:11 AM   #11
Base drive voltage is the voltage supplying current to the base. It could be VCC which would reduce the number of measurments you have to make. Fixed VCC will simplify matters because you don't have to measure it with the micro.
Russlk is offline
Old 7th April 2006, 02:13 PM   #12
yes i think its a goo idea. i dont want to see the gain trough an anlaouge meter cause i need to determine if the gain of the tested transistor is bigger of smaller than a certain value.
thanks nigel
crowinu is offline
Old 7th April 2006, 03:17 PM   #13
thanks nigel
That was why I said to measure the collector voltage and calculate the current - a simple job for a micro-controller.
Old 9th April 2006, 04:44 PM   #14
thanks nigel
You don't need a microcontroller. You could do this with a comparator, unless you are doing it as an assignment for a class.
Ron
Roff is online now
Old 9th April 2006, 04:50 PM   #15
I was basing that on his earlier post!
Presumably it's a class project, or he wants to add more functionality?.
bipolar, hfe, tester
