Old 5th July 2003, 11:12 AM   #1
Default 4 channel IR remote control
Im a student major in science physic. Im a third year student, so I have to do a final year project. My title is building a Remote control by using Infrared. I have no ideal how to do the circuit which can on 4 LED in different time by using 4 buttons remote control. I know how to do single channel on off, but come to 4 channel I face difficulty. So I want to ask for help here to build up this circuit with diagram, and please list out the electronic component name, so that I get to know what it is. And tell me how it works, the voltage direction, current flow and .. . thanks for your help. Good luck!
mengchan is offline
Old 5th July 2003, 12:38 PM   #2
okay, well if you wanted to cheat, and nobody was going to open it up, I'd say make 4 seperate cicuits, combined into one, using 4 seperate IR LED's with different wavelengths.
But I'm sure that won't work, and since my knowledge with IR is limited, I couldn't help you.
Nostrafus is offline
Old 5th July 2003, 02:06 PM   #3
Default IR
I suggest using an IC such as HOLTEK HT12A coupled with a HOLTEK HT12D which will allow 4 different signals to be sent and received from using only one LED and a photodiode. Only a few extra parts are needed and the whole will not be very expensive.
Will Neo wake up and say, \"Bill, dude, you won\'t believe this bitchin\' dream I just had...\"?
sam_h is offline
Old 6th July 2003, 10:21 AM   #4
how about combining the Motorola MC145026 emitter with the MC145027 receiver wich can send 8 different signals.......
just hook up the output if the circuit to an IR emitter and use a IR receiver to the other side and thats it.
as if you want to have one push of a button to turn on the led and another one to turn it off.....you need to connect each output to a flip flop.
also ...i have to mention that the chips have 8 input/output pins wich are 3 state, not 2.
bogdanfirst is offline
