Old 19th March 2006, 01:21 PM   #1
Default ECU Information
hello
I want to develope an electronic tool that will interact with car via obdII connector and with pc via usb.
as there are: comunication protocols: OBD-2, WPW, PWM, CAN, ISO. KeyWordProtocoll: for each model
i need to find: information about the way all the ECUs communicate and if there is a common way for all ECUs of the same kind (in example BoschME7.5 and siemens Serious 32 are both OBD-2 ECUs)
thank you, I hope you can help me please
PCB Electronic
PCBElectronic is offline
Old 22nd March 2006, 06:15 AM   #2
Hi
in order to communicate with the ECU you need a USB-OBDII cable i found the following link can help you get the cable and all you need to do the job is to know the protocols of ECU and you can get it from the car manufacturer
Kamal Daniel
http://www.ecutool.com/516880106USB.htm
kamdy is offline
ecu, information
