| Hey, I have a question regarding the L298 dual H bridge driver. I am using one in conjunction with an L297 stepper controller and a dsPic, to drive a 1.2A/phase bipolar stepper motor. The supply voltage to the motor is 15vDC, but this is obviously chopped to keep the current at 1.2A/phase. My question concerns the L298, and more specifically the method of how to calculate its power dissipation. For the other higher current h bridges I am using, I know the resistance of the MOSFETs so I can work out power by P=I^2 * R. For the L298, how should I work out what the power dissipation is? I know the current but I don't know the voltage drop between the supply and the motor - or am I able to work this out from the motor specifications (coil resistance, inductance etc)? Any help you are able to provide will be most appreciated Jason | |
| You can't compute the power without knowing the voltage, so unless you have a datasheet or are able to measure the voltage drop, you are out of luck.
| Thanks for the reply. I realise I need to know the voltage, but how would I work this out? Particularly as the L298 is being run by the L297 and hence at a 20kHz chopper frequency. Should I measure the average voltage across one of the coils of the motor? And then using (15-motorV) * motor current per coil * number of coils, this should give me the power dissipation? Many thanks Jason | |
| I'd be inclined to simply run it and see how hot it gets! - as crudely as a damp finger if that's all that's available. You're using a 15V supply, is the motor actually rated at 15V?. | |
| The motor datasheet says and I quote: "Power supply voltage can be any value as long as the driver output current is controlled at the rated current." The motor specs are: Bipolar stepper motor 1.2A/phase 3.0 ohm coil resistance/phase 2.1 mH coil inductance/phase Unfortunately I can't run it and see how hot it gets as I am at the PCB design stage (the stepper drive is part of a larger system) and I need to allow space on the PCB for the heatsink if necessary, or combine it with the other two H bridge (discrete) heatsinks. Is there any way of calculating the power dissipation from these specs? All I have to go on is in place of the actual unit I am testing using a late 1980's robot arm stepper controller (not using an L298 but it looks very similar) and the heatsink is the size of a small housebrick.... it barely gets warm however so I assume I need something smaller! Many thanks Jason P.s., no idea why ohm is a link to this page, there is no link in the text here! | |
If you google for "stepper motor tutorial" you will find plenty of information about it!. As for trying it, you could breadboard the design and test it like that - which is probably a good idea anyway!. | ||
| The data sheet (what's that?) lists the voltage drop as 3.2 volts at 1 amp. If you plan on 4 watts dissapation at 1.2 amps, you should be OK. I don't know anything about stepper motors, but assume only one coil is driven at a time.
| are you planning to half step? it's good to reduce resonances and get higher speed but does increase the concurrent coil current. 3.2V drop is suprising to me - there are 2 bipolar transistors in each energized circuit so I would have guessed somthing on the order of 1.4V but I wouldn't bet against the datasheet Note that with half stepping, you will need to add 50% more current due to the overlap. Definitely use a beefy heatsink. I'd also add a header to power a fan in case your heat sink isn't enough. the 297 is a current sensing chopper so no resistors are needed. Man, I sure don't like the L298 - a real heat generator, needs a stepper controller and talk about a prototype unfriendly package. Any reason you didn't use the A3977? Uses DMOS output transistors for much less heat generation. other than a hard to solder plcc package, it's pretty nice. | |
Philba - Yes, half stepping will be employed intermittently (when the error in the control loop gets below a certain threshold). Yeah, the L298 is a pain isnt it! To be honest that is the first I have heard of the A3977.. but it looks really good! Unfortunately I am pretty far along with the current design and as I have about a week to route the PCB from tomorrow it is a bit late to change.. but definitely on the list for v2! Thanks for all your replies, much appreciated. | ||
| have you looked at the open source designs on http://pminmo.com/ ? there is at least one allegro 3977 based design. several 297/298 ones as well. schematics and artwork included. Phil | |
