Old 13th March 2006, 03:28 AM   #1
Default Bipolar power supply with digital control
I intend to build a bipolar, variable, lab power supply (non-switching), say plus and minus 3 to 25 VDC @ 1 to 1.5 amps. The National datasheets for the LM317 regulator series shows such an application, however the output voltage is set for both the positive and negative regulators using a ganged dual pot.
I would like to replace the dual pot with with a device(s) that uses a control voltage (from a microcontroller) to set the output voltage. Where things get fuzzy for me is the complimentary control element for the negative regulator. Any ideas?
GizmoWizard is offline
Old 13th March 2006, 05:19 PM   #2
Default Re: Bipolar power supply with digital control
Do you want one power supply that will swing both positive and negative (through zero), or do you want dual tracking positive and negative supplies?
Ron
Roff is offline
Old 13th March 2006, 05:31 PM   #3
I need the dual tracking positive and negative supplies.
Old 13th March 2006, 07:16 PM   #4
Here you go. I haven't built this, but I think it will work.
The references in the LM317 and LM337 aren't used to control the output voltages. These regulators are simply used as bullet-proof, high power voltage followers. Due to the voltage across the regulators, you will need massive heat sinks if you want to run high current at low voltage.
EDIT: Fixed polarity of C10.
Thanks to L. Chung.
EDIT: Added balance pot.
Ron
Roff is offline
Old 14th March 2006, 12:35 AM   #5
Wow Ron! I wasn't expecting you to go to this much trouble. I thank you very much.
I don't understand the LM317 and LM337 (with their Adjust pins tied to gnd) feeding the op-amps. How does this work please?
Old 14th March 2006, 03:40 AM   #6
I was afraid you were going to ask that. First, notice that they are the "L" versions. in TO-92 packages (or maybe SO packages).
It's a long story, which I am going to make short. The op amp outputs are always 1.25V below the output voltages. I wanted to power one of the supply rails from the output, and the other as close to GND as possible, in order to minimize the voltage across the op amp, and to maximize the output range. These requirements called for a (relatively) high-voltage, rail-to-rail op amp. The LT1677 fits those requirements, but I was not comfortable running one rail at GND when the common mode input voltage is at GND, so I made the other rail 1.25V. Hence the LM317L and the LM337L. They put out 1.25V above and below GND, respectively.
See, I told you it was a long story. And that was the short version.
Ron
Roff is offline
Old 14th March 2006, 08:31 AM   #7
Polarity of C10 is shown reversed. This is an easy mistake to make when drawing +/- supply circuit. I have done the same many times.
L.Chung
eblc1388 is offline
Old 14th March 2006, 02:53 PM   #8
Oops! I copied and pasted it. ops:
It's been fixed. Thanks, LC.
Ron
Roff is offline
Old 14th March 2006, 04:30 PM   #9
I'll order the op amps, breadboard the circuit, and let you know how it works out.
Thanks again,
Giz
Old 14th March 2006, 06:47 PM   #10
Thanks again,
Giz
Ron
Roff is offline
Old 14th March 2006, 11:36 PM   #11
I wonder if you couldn't simplify the design by using a pair of Maxim digital pots wired with the 'up' and 'down' push-button inputs in parallel and the variable-resistor outputs controlling the adjust pin on a pair of regulators?
Never mind... Ron's design is better... Forgive me, I posted before thinking (duh)...
Regards, Mike
Mike, K8LH is offline
Old 15th March 2006, 02:53 AM   #12
Thanks again,
Giz
To get the best possible match between Vpos and Vneg, you might want to put a 10k pot between R1 and R2, with the wiper going to the inverting input of U2. I've modified the schematic above.
Ron
Roff is offline
bipolar, control, digital, power, supply
