| i've found a h bridge circuit. i need to supply 12V to the motor, and my signal can only be 5V. when the signal supply to a, the motor goes forward, when the signal supply to b, it goes reverse. i've tried both the circuits A and B. it gives only 5.xxV output. but when i change the signal to 12V, it gives a 11.xx v output. can anyone help me?? i need to control it with only 5V signal to move the motor in both direction in 12V. thanks for helping. | |
| Well you need to supply 12V to A and B otherwise the top switches wont switch (I am supprised they are!!!! esp since the emitter will be jumping) If you want to control from 5V you will need another BJT that takes in 5V to turn-on, but the Collector (via a resistor) is tied to 12V, the collector connection (which will now toggle between 12V and ~0.6V) can now be tied to the point you want to control | |
| can anyone solve my problem??? thanks!! | |
| That's a very poor design, have a look at http://www.lpilsley.co.uk/cybot/driver.htm for some better ideas. | |
| anyone can solve my h-bridge problem?? | |
| | (permalink) | ||
| | (permalink) | |||
Here are a few I have found (taking from the first page of a google search). http://www.mcmanis.com/chuck/Robotic...t-circuit.html http://www.bobblick.com/techref/proj...e/hbridge.html http://www3.telus.net/chemelec/Proje...H-Bridge-1.png
__________________ "Having to do with Motion Control" | ||||
The example I gave the link to is from a magazine robot called Cybot, it's not intended to be copied 'as is' but as an example of how an H-bridge works. I wouldn't say it's a great example, but it is considerably better than the NPN only example!. | ||
| | (permalink) | ||
| | (permalink) | |||
__________________ L.Chung | ||
| | (permalink) | ||
| if other transistor can be used.. then what is the transistor?? please help.. thanks!! | |
