| | LinkBack (2) | Thread Tools | Display Modes |
range depends on the current thru the (ant) loop ., need to check it . | ||
| | (permalink) | ||
2. how to increase the Tx frequency? 3. the VR at the Tx, i only need to turn it until i get 5.6K right? or it is a frequency tuner? | |||
| | (permalink) | ||
now freq of 555 is 1.44/(Ra+2Rb)*C adjust Rb or C as per ur need. | |||
| | (permalink) | |||
i've try this circuit, since i cannot get a 0.027uF, i took two 0.056uF in series to get 0.028uF, but the output i get is exactly same as the supplied, nothing to do with RF... why? | ||||
http://www.uoguelph.ca/~antoon/gadgets/555/555.html also u need "..since i cannot get a 0.027uF, i took two 0.056uF in series to get 0.028uF, but.." such type of adjustments . use any nearest value u get. | ||
| | (permalink) | ||
| another question... what is the output at the receiver? is it the same pulse as the 555 timer? | |
__________________ Gods own Country Incredible !ndia www.flickr.com/photos/_akg/ "Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime." | ||
| why must the output of the 555 timer (after the 100R) be connected to the GND (-ve terminal of the battery)? can i connect it to nothing? as an antenna.. | |
| | (permalink) | ||
| | (permalink) | ||
It might work not grounded. It has a better chance of working if it's grounded. Try it both ways. If it works when not grounded, use it that way. It will save power. | |||
Connecting a pull-up or a pull-down resistor with a very low value is IMO a bad idea, because current can be wasted that way. Why not just add a transistor FM transmitter circuit and connect it's "Signal In" to pin 3? An FM transmitter is also available from antoons Page. See the url that someone posted above as part of their answer.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | ||
| LinkBack to this Thread: http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/20260-radio-frequency-circuit-design.html | ||||
| Posted By | For | Type | Date | |
| Positioning systems? - Hobby, Science, Consumer Robots From Around the World | This thread | Refback | 29th May 2008 09:06 PM | |
| Positioning systems? - Hobby, Science, Consumer Robots From Around the World | This thread | Refback | 21st May 2008 06:08 PM | |
