Old 8th March 2006, 01:59 PM   #1
Default Current transformer selection....Guidance needed
Hi all,
First let me give a brief introduction to the circuitry.
The ade7758 evaluation board can take 22mA current.
But Energy meter manufacturers usually specify their buden as 1A or 5A.
So if we do that, then we have to incorporate an internal CT.
The internal CT will have
Primary current : 0 to 1A.....(or 5A)
secondary current : 0 to 22mA.
Can a get a CT like this??.
Other option is to use a 200:1 CT internally, then
If we specify the burden of our meter as 5A, then we get 25mA, which can be
given to the evaluation board.
But the problem here is I'm unable to find a 200:1 CT with 0.1% accuracy.
The 0.1% is mandatory as the ade7758 is having the same accuracy.
Please help me out by getting me few links for getting a high precision current transformer. I tried out in google....but i did not get the required results. suggest me some good search strings for google.
tkvenki is offline
Old 9th March 2006, 01:09 AM   #2
What kind of board is this? I have no idea what a ade7758 evaluation board is evaluating :lol:
Is the transformer you need a power transformer (from the wall) or a transformer on the board to match impedances, step up voltage . . .?
What's the difference between a current transformer and a regular transformer?
zachtheterrible is offline
Old 9th March 2006, 01:22 AM   #3
Zach, a current transformer is often a toroid shaped core with a large number of current sensing turns around it. The wire ( or busbar) that carries the current to be measured is fed through the core (or loped around it a few times).
The ratio of the windings lets you measure large quite currents with a small scale meter.
These CT's only work for AC, naturally. One precaution is to short the sensing wires before the meter is removed as an open circuit sense coil can develop a dangerous voltage at its terminals.
CT's measure current without having to interrupt the current carrying wire /busbar. The clamp on Ampmeters work on this principle too.
Klaus
Klaus is offline
Old 9th March 2006, 08:26 AM   #4
In a nutshell, whereas a voltage transformer (or power transformer) gives you a ratio of the input voltage, a current transformer gives you a ratio of the input current at the output.
Phasor is offline
Old 10th March 2006, 12:42 AM   #5
Hi tkvenki,
don't see a problem with such a CT.
Why do you think there's a problem ... ?
john1 is online now
Old 10th March 2006, 12:48 AM   #6
Unless its the accuracy thats concerning you ... ?
you can make your own small adjustments externally if you are that
concerned about the 1 per cent accuracy.
Most of them would be in that area of accuracy anyway i would think.
Its easy enough for you to check for yourself.
john1 is online now
Old 27th October 2006, 08:32 AM   #7
small adjustments should be made, my design works very well.
tiger_king is offline
Old 27th October 2006, 10:12 AM   #8
you should be able to get a very accurate ct - at a set point - it's the linearity that is difficult.
here is a link
Drake Transformers Transformer Designer. 1992-1997
Dagnall Electronics / Clairtronic Transformer Designer. 1997-2009
Now going it alone
grim is offline
Old 27th October 2006, 01:29 PM   #9
just put a current limiting resistor in your CT secondary
penoy_balut is offline
Old 28th November 2006, 05:27 PM   #10
Question ADE7758 SPI Cmmunication Register
Please help me how to access the ADE7758 Register.
I interface the ADE7758 with MCU. I wrote SPI Communication program but the outcomes values are inproper.
Please let me know how to proper way access the ADE7758 Register.
If possible please mail me on: vivek_acharya21@yahoo.com or
call to me on +919925226614
vivek_acharya21 is offline
current, needed, selectionguidance, transformer
