| Hiya Guy's, Well I finally got some time to tinker with my electronics( da missus ain't home) and I got my 3 watt led setup as a night light for when I walk back to the house. This led is shining a path around 30 metres which is great but ideally I want to set up a 5 minute time delay so it switch's off automatically. My first thought was using a 555 but with that type of delay I'd need a bigger cap than is recommended. I did see a few years ago a work around for longer time delays but after searching I keep coming up with blanks. I could use a pic but thats overkill so does anyone have any reference to using long delays with the 555? Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | |
| Hiya Nigel, I suppose your right there and I do have a few 12f675's around and I am in the process of making up a pic based rpm meter so it won't be hard to write up some code and use the pic.I just thought for a simple circuit that I need, a one shot 555 would be the easiest. Cheers Bryan
| Example on AVR here: " Long Delay Generation Using the AVR Microcontroller " http://atmel.com/dyn/resources/prod_...ts/doc1268.pdf | |
| If you can find one, a ZN1034 IC will do just what you want. It is a long delay timer, made by Ferranti, (now defunct). It contains the circuit for an RC oscillator followed by a divider circuit. So the oscillator can run at a relatively high frequency, but the output delay can be hours or days etc. Just had a separate thought, you could use a 555 as an oscillator follewed by a 4040 12 bit counter to give a long delay. JimB
| A CD4541 can be programmed to time seconds to HOURS. 5 Minutes, No Problem. Probably quicke to make than programming a pic.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
