Old 21st February 2006, 02:34 AM   (permalink)
Default Problem with my Project: Motorised volume control
Hi there, I have been assigned to this new project recently and I am completely lost. I know little about PIC; therefore I hope some people can help me out.
The aim of my project is :To be able to drive a potentiometer over a specified range of attenuation ratio using a stepper motor
• Input: Up/down momentary action pushbuttons to control movement of the potentiometer. Also a sensor must be provided to detect the ‘home’ position of the potentiometer.
• Output: Hybrid 200-step stepper motor whose coil phasing must be controlled by the PIC.
I am researched little on the stepper motor and some notes on the PIC16F873. I think I will divide the project timeline into 2 sections. One on Software and the other on Hardware. I have 10 weeks to do this project. Hopefully there is enough time. Other than that Im not sure where to go.
Sorry, I am a total newbie in this and I do need some guidelines/help on this project. Please give me some ideas.
Thanks a lot!
zenigame211 is offline
Old 28th February 2006, 04:26 AM   (permalink)
Any suggestions people?!?
Old 28th February 2006, 05:25 AM   (permalink)
the stepper motor is rotated by giving a sequence of pulses in it's input , which can be generated using a PIC, to reverse the rotation , reverse the sequence . giving the seq i/p one by one will step the motor . a micro switch like thing can be used to sense the home location.
akg is offline
Old 28th February 2006, 05:57 AM   (permalink)
Thather than thurning an pot whith a motor it would be a much better solution to get an digital pot IC.These ICs conect in insted of a pot and can comunictae whith an MCU over varius comunication protocols or by an simple up and down input that can be wired to a switch.
Il give you shocking experience.
Someone Electro is offline
Old 28th February 2006, 06:14 AM   (permalink)
probably that is not his req.. may be a demo for a closed loop system with micro.
akg is offline
Old 7th March 2006, 05:18 PM   (permalink)
Can anyone still help me!?? I am still very lost. I cannot get the hardware design going. I have no idea where to go... I've searched for books and internet sites and still cant put myself on the right track.
Old 8th March 2006, 02:25 AM   (permalink)
What does it mean by Up/down mometary action push buttons?
I know a buffer needs to be used to control the current. But can anyone tell me exactly the theory of a buffer? and how can it be used when apply to my project?
cheers,!
Old 8th March 2006, 03:28 AM   (permalink)
OK, I think you should at least provide a block diagram. If you don't have that, at least in your mind, you may not be cut out for this field. Speaking of field, what are you studying, or what career are you pursuing?
Ron
Roff is online now
Old 8th March 2006, 03:59 AM   (permalink)
an easier way is to make or get a hold of a DAC.
Add a digital up/down counter to the inputs of the DAC and you can use the up and down functions of the counter to change the output resistance.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 9th March 2006, 01:42 AM   (permalink)
got this from electronic goldmine its a 20k ohms pot ,worm gear driven.
musthave is offline
Old 9th March 2006, 02:00 AM   (permalink)
I am only in yr 1 Electronic and Electrical Engineering. I am not good in Micro controllers, therefore I am very worried about this project. It seems like I have no idea where to start off or am I actually on the right path.
Old 9th March 2006, 02:09 AM   (permalink)
I think I need to use an Astrosyn MY5002 mini hybrid stepper motor. I know the stepper motor require large currents if the load needs large torques.
I heard from my mates that I need a transistor array?? sth like that to drive the volume control... I don't understand why and what can I do with this though.
Old 9th March 2006, 03:07 AM   (permalink)
You're in your first EE year? Have you taken some electronics classes?
Well, like I said, you should start with a block diagram. Against my better judgment, I've drawn one for you. Once you have one, you can start identifying the pieces.
I showed the motor, the cam, and the pot all on one shaft. Obviously, they could just as well be connected by gears or belts.
If you have to control coil phasing with the PIC, you will need a simpler driver than one that takes step and direction as its inputs.
BTW, I don't really know much about steppers or PICs - just what I've gleaned from the Internet. That and 40+ years of stuff accumulated by osmosis.
I guess what I'm saying is, don't expect me (or anyone else) to design this for you. I have difficulty believing you would be assigned a project for which you have zero training.
Ron
Roff is online now
Old 11th March 2006, 02:41 AM   (permalink)
Hi there, Thanks for your reply. I am not relying on anyone on this project. I just want someone to start me off so I know I am on the right path. I have done some micros in semester one and some basic analogue and digital electronics before. Hopefully I am alright.
As you said, the motor is connected together with the cam and pot in one shaft. I don't really understand that. Can you explain it more in depth. Thanks!
Old 11th March 2006, 03:55 AM   (permalink)
Why don't you explain how you propose to connect the motor to the pot, and how you plan to locate the home position? Then we can give you some feedback on your ideas.
Ron
Roff is online now
