I'd like to do some big electronic project using microcontrollers .. preferably AT89S51 / AT89C51 ... and embedding on chip using C , flash programming etc.. Project duration 1 - 1.5 months Can also use Keil C Compiler etc.. Hope u guyz come up with interesting suggestions.. I'd also need ideas to do projects based on PIC microcontrollers | |
bump! I really thought someone could provide me with some nice ideas..
try a system that represents a workplace factory, where...lets say 3 conveyor belts load boxes onto the trucks to go to shops, you will need a sorting system so that u program how many boxes goes onto each conveyor belt......if u hav any questions about this, or think it is unclear just ask
__________________ <( \"<)....kirby!!!....0==[=====> | |
| | #4 | |
So something to do with electronics is preferred.. Communication is also OK | ||
hmmm...yeh, i'm a systems technology student :shock: . You could allways make a room which contains a fan that only comes on when it is a certain temp, also include a temperature guage so u can see the temp inside and outside of the house.....the good thing about making a room as your project u can add anything eg. a light that only comes on when it senses some1 in the room and it is a certain darkness, you could even include a burglar alarm for the room, and you would hav it all controlled from a swithboard outside the model room......i'm not sure about the communications part though..... :?
| | #6 | |
| | #7 | |
I was thinking of something more cutting edge .. like embnedding into chip using C code (Keil C Compiler) & control using microcontrollers .. etc.. btw I'm from India | ||
| | #8 | |
now u need "cutting edge" try this http://www.electro-tech-online.com/v...ic.php?t=20218 it's ok for an E&C student as final proj. | ||
| ideas, project, suggestions |
