| hi friends, today i had a wireless phone for repair and its handphone have a cordless power circuit, it can be charged like a primary and secondary transformer and since it use from high frequency system rather than that normal 50 or 60Hz transformers it must be smaller than that common transfers, but after taking the hand phone apart i saw that there is a very thin board with less than 15 number of coil and without any iron or Ferrite, the freq maker(oscillator) for the primary has one transistor and a few other components, it would be very ok if some could suggest any circuit for these nice smal transducers, how know how many freq the oscillator produce in these devices? do you think if i make a coil as secondary with different numbers then it can produce power without any other component?(the original secondary can produce more than 8V) | |
| i tested the primary with an only 15 number of wire as a coil (as secondary) and could lighten a 6V lamp, that is good and now i need for a circuit for primary(as an oscillator,ok?) but i dont know what kind of circuit is ok?! i have no info about primary coil freq and voltage( the primary is a 3 wired coil that has the third wire at center). i can not to measure the primary voltage with a volt meter, it seems it produces a squre wave not a sinus wave, i am wondered why there is no info or circuit about that transformer in the net because its structure seems to be simple(there is less than 20 components on the primary), i dont know, perhaps my key words was not so right :roll: | |
| some basic ideas you could experiment with: use a 555 based timer to switch current on and off into a large coil of wire (your primary) use a second smaller coil with a rectifier, some capacitors and some sort of load, to see how much DC voltage you get my idea is, the 555 timer switching current on and off into a coil will generate an electromagnetic field around the coil. another coil will absorb some of that energy through induction. then the rectifier and capacitors will smooth it into DC, and you can power your load with it. of course, using something a bit less crude than a 555 timer, like a sawtooth or sinewave generator would produce better results, but a humble square wave might be enough to get you started be sure to snub the back voltage your coils will generate when the input current is turned off | |
| | (permalink) | ||
and 10 number for primary,(yes i know the difference between secondary and primary:lol: ) the phone is a Sanyo and i am agree that it is huge ampere drawer, ho w can make a guess how many volt is in the primary coil? i can not measure it with voltmeter | |||
please correct me if i am wrong: i dont think i need for an ON and OFF timer, i think i need for an oscillator , and if i want to use from 555 IC then i need for 2 IC to CHANGE polarity very fast. with one IC i can not change polarity. | ||
otherwise if the core is non-saturating type , then also 555 can be used. further u can produce bipolar signal with 555 (not alone). | ||
| | (permalink) | ||
do you mean i use from 4 transistors on output of one 555 to produce a bipolar polarity? is there another way rather than 4 transistor output with 555? a 555 can produce near 1.5A on output so i prefere one or 2 ONLY 555 without transistors in output | |||
| i want to make anothe search in the net but i dont know which key words are better, can anyone help me please? | |
| | (permalink) | |||
yes you are right | ||
| ok, here is the circuit, it has 2 transistor not one, an IC for reducing the voltage, i think to 12V but i am not sure. it has a 2.6Ghz crystal sso it might to oscillate near 26 000 000 000 time per second, i think i am wrong becuse i dont know any transistor the could make oscillate so high :shock: ?! beside i never seen a crystal so high :shock: what is your idea? who can explain the circuit? | |
| i can not understand why there is a 2.56GHz crystal while 2 transistors can not oscillate more than 250MHz? really one is 100MHz and the other is 250MHz! | |
