| ello everybody, I am into building my own CD motors for planes. Now I need to take this to the next step. Since it is hard to keep batteries fully charged and to run more accurate tests on my motors I'd like to make my own DC adjustable power supply. I was looking at stuff I might need: Volt panel meter: http://www.allelectronics.com/cgi-b...NEL_METER_.html http://www.allelectronics.com/cgi-b...ETER,_20V_.html Amp panel meter: http://www.allelectronics.com/cgi-b...NEL_METER_.html I am not sure but I am guessing I could use a computer power supply like this: http://cgi.ebay.com/600w-Dual-Fans-A...QQcmdZViewItem The power supply description says it has an output of +12V 24A ( perfect ) to test CD motors. What I have no idea is how to connect them together or how to regulate volts ( from 7 to 12 ) and amps ( 1 to 24 ) going out of this jig. I have no electronics knowledge and there is only one thing more dangerous than an unknowledgable person, an unknowledgable person with initiative If somebody could direct me on stuff I need and a diagram or if this is possible. | |
| What is a "CD motor" - or are you dyslexic? | |
I am talking about motors that I take out of CD rom Units for Rc planes, I rewind the motor, replace the magnet ring with strong magnets and here is the result... Motors that can pull 23 amps at 11 volts ( that is if you set it up with a big prop) | ||
| On and on! :lol: Cool motor! I had done a Google search, but if they were found, I missed them. Is there a web site about CD plane motors? Unfortunately, I don't have a simple answer to your question, but maybe one of the other guys does. | |
www.little screamers.com www.gobrushless.com here are 2 videos of my motors: http://arrobba.com.mx/~ecologito/22gaugemotor.mpg http://arrobba.com.mx/~ecologito/22gague5prop.mpg | ||
| So do you power these off lithium-ion batteries, or ??? How much flying time do you get from a charge? | |
| The Little Screamers are extremely lightweight, powerful and maneuverable. This summer I glued together and painted a styrofoam plane I won. The latex house paint I used was way too heavy but held the plane together each time it crashed. I used a cheap geared motor that just barely had enough power and the plane flew something like a brick made from cereal. The PWM motor speed control circuit I designed worked very well. I used a heavy 8.4V Ni-MH battery with too much capacity for it to fly nearly all day!
http://media.putfile.com/GBx-Plus-Super-Modified-Motor Now back to topic, can somebody help me? | ||
| Those put-files take way too long to load.
| i did wait a while, and tried twice, i got the impression it wasn't going to load and gave up. John | |
| I tried the Put-Files site at almost 3:00 in the morning and it took 10 minutes to load the 4+ minutes video (800 res) on my broadband connection. At 10.6V the fantastic little motor drew 23.5A (249W!), ran a propeller at 18,950 RPM and had a thrust of a whopping 1lb-12oz. They measured its temp which wasn't too hot.
| Yup, that little motor can handle and deliver lots of power, What about my plan of having a volt adjustable power supply that can handle up to 25 amps? | |
| Yes, at $80 its much cheaper than building one. Quote:
__________________ L.Chung | ||
__________________ "Having to do with Motion Control" | ||
