Old 29th June 2003, 01:20 AM   (permalink)
Congratulations! You didn't give up. Feels pretty good, huh?
Mosfet is offline
Old 29th June 2003, 05:27 AM   (permalink)
Mofset......
Feels great ! I am a happy camper. I was not about to give up ! The application I am using it for works very well and the circuit is perfect although the only problem is the tip of the conductor probe is getting eaten away a little at a time so that makes for constant adjusting.... If I lowered the voltage requirement can I still make it as sensitive ? Now the Darlington would be a good canidate right ? Doesnt it help increase the voltage so I could drop the voltage going into the probe...... I wonder if it would still get eaten up as bad ? I started turning it off as soon as it contacted the water and I got a reading.... that helps.
As far as the water level I made... Its a little crude but accurate over a 10' distance to about .002"-.003". I took multiple readings and averaged out the differance measuring with calipers, and it could be improved to a consistant .002" if I tighten everything up so measuring can be more consistant....
Anyway - Thanks again ! I appreciate it a lot.
eightwgt is offline
Old 29th June 2003, 11:44 AM   (permalink)
Try using a silver or gold plated probe. It won't oxidise as easily.
Phasor is offline
Old 29th June 2003, 07:57 PM   (permalink)
Use stainless steel probes. They won't have any problem of rusting or other reactions. I have used in my water level controller and its still working since past 6 years.
kinjalgp is offline
Old 29th June 2003, 11:17 PM   (permalink)
Or you could use aluminum, it's already got an oxidized coating and water doesn't damage it, that's why it works so well with soda, I mean hell, soda is basically a weak acid and it doesn't even scratch aluminum, and even if it does get a scratch in the aluminum past the oxide coating, exposing it to air for roughly 30 seconds will put a new one over the scratch.
Nostrafus is offline
Old 20th April 2004, 09:25 PM   (permalink)
HEY GUYS
BEEN A LONG TIME........ but here is what I used that little gadget to build....... (well help build )
http://www.inshorepowerboats.com/cnc.../CNCROUTER.htm
Thanks again
Tom
PS anyone know any ideas on a DC motor control ??? :shock:
eightwgt is offline
Old 5th May 2004, 06:30 PM   (permalink)
Originally Posted by eightwgt
Mofset
Thanks again.....
i just got an assortment of resistors... trying to figure out which is the 470 !!
Yellow, Violet, Brown (then gold/silver for tolerance)
Steve
Crofty is offline
