Old 26th June 2003, 03:41 AM   (permalink)
Default Car Locator Schematics
I have a few questions about this schematic...
http://www.schematicsforfree.com/mis...AR_LOCATOR.GIF
First.. I don't see a power source for the receiver.
Also, the secton of the receiver with the leds, doesn't that need a ground somewhere? I only see one wire going to all of that..
Please, someone look over it and tell me if they think it will work. I am pretty new to making this kind of thing... so I don't really know much about it.
Thanks!
TAF
taftech is offline
Old 27th June 2003, 10:50 PM   (permalink)
Default anyone?
Can anyone help with this?
What I am actually looking for, is a way to transmit an RF, up to 100 feet or so, and a reciever that only needs to be able to know whether the signal is present or not.
Please help! Thanks
taftech is offline
Old 28th June 2003, 12:07 AM   (permalink)
Neither do I... That's really wierd, the positive is grounded also, hmmm... I think someone screwed the pooch with this one, or made the thing backwards, the negative should normally be grounded... that's really wierd...
Try here...
http://www.electro-tech-online.com/viewtopic.php?t=49
and get a walkman, or something, the closer you get to your car, the louder and clearer the signal gets.
Plus you can follow the blinks of the light, however this one doesn't turn on or off via transmitter.
Sorry man, don't know what to tell you.
Nostrafus is offline
Old 29th June 2003, 07:47 AM   (permalink)
The transmitter is not the best design but it will work. But from the inductor value shown it will transmit in the long or medium wave broadcast bands, so it will be difficult to detect among all the high-powered stuff being broadcast there.
The receiver will never work - even with the correct power supplies. There is no form of detection - such as a diode - and the 741 is just operating as an amplifier. It could amplify audio frequencies OK but there is no way it can deal with frequencies in the broadcast bands. It was never designed for that.
If you want to make such a device, do a Google search for FM transmitters and receivers. There are plenty of them published.
pebe is offline
Old 29th June 2003, 03:52 PM   (permalink)
Thank you pebe, for analyzing that for me.
What I would really like to have:
A transmitter with a variable switch that could make the transmitting range between 2'-100'.
A small reciever to accept the signal.
Both, operating on a frequency that would not interfere with other electronics.
The transmitter and reciever only need to be very simple, sending only a single signal between them.
Any input would be bery nice.
taftech is offline
Old 29th June 2003, 04:42 PM   (permalink)
I can't see mentioned anywhere how this car locator works.
Is the transmitter fitted in the car and switched on at all times when you have parked the car, and you carry the receiver?
pebe is offline
Old 29th June 2003, 09:54 PM   (permalink)
correct pebe, that is of course if hes trying to do the same thing that i've been trying to do for months now
thanks,
david
daviddoria is offline
Old 29th June 2003, 10:31 PM   (permalink)
Coming into this with an open mind, I think I would have carried the transmitter and had the receiver in the car - like a remote door lock.
The receiver could have had a relay connected that blew the horn when the transmitter was keyed at a distance. How about that?
pebe is offline
Old 29th June 2003, 11:28 PM   (permalink)
Yes, I believe this was supposed to work that way. Also the number of leds lit indicate how close you are to the car with the transmitter.
If the car carries the transmitter, then you can measure how far away the car is with the reciever.
taftech is offline
Old 30th June 2003, 04:01 PM   (permalink)
I think you could have trouble getting any meaningful information from the number of LEDs lit up. In a car park the transmitted signal is reflected many times by the metal of all the cars and you can end up with 'dead spots' where you can get no signal, so the LED indication would change as you move about. And how do you know in which direction to go towards your car?
If many people use these devices you could end up by finding the wrong car. :?
If you want to purchase modules to make up the transmitter and receiver then do a Google search for RF Solutions. I think they are international and their bits are sold in the UK by RS, Maplin and probably Farnell. These modules operate in the bands 418 to 434MHz.
Good luck.
pebe is offline
Old 30th June 2003, 06:08 PM   (permalink)
Yes, I realize there are many things wrong with it, even if the schematics did work. However, as I said before.. this is not my intended use for the device.
I have been looking around for different RC moduels, and found these:
http://radiotronix.com/ewmprod.asp
Any idea how hard these would be to use?
taftech is offline
Old 1st July 2003, 04:57 AM   (permalink)
Originally Posted by taftech
...I have been looking around for different RC moduels, and found these:
The link gives prices per 1000 units so it looks like they only sell to manufacturers. Also their download for datasheets doesn't seem to work.
pebe is offline
Old 1st July 2003, 10:44 PM   (permalink)
The transmitter and reciver only need to be very simple, sending only a single signal between them.
Try using a POT to ajust the range
thanks,
Smart
Smart!
eggelec is offline
Old 1st July 2003, 11:02 PM   (permalink)
Today cannot found a pure frequency,except on GHz-band. My opinion:hopeless to found a car without directional aerial and receiver with hand variable sensitivity. (think about "fox-hunting" sport)
Sebi is offline
Old 1st July 2003, 11:59 PM   (permalink)
Default Re: Car Locator Schematics
Thanks!
TAF
Dear TAF,
There two lines comming out of the led's aren't there try using the line comming out of the flat side (The side with the horazontal line) as base.
Smart!
eggelec is offline
