Old 9th January 2006, 08:41 AM   (permalink)
Default Oscillator
Hi......
How to fine tune the output of the following oscillator?. Can I connect directly regulator circuit with the following circuit. From the experiment, it seems was a bad idea and the voltage output suddenly drop. Any suggestion are welcome....
zefiris2K5 is offline   Reply With Quote
Old 9th January 2006, 09:00 AM   (permalink)
akg
which regulator ckt..??
akg is offline   Reply With Quote
Old 9th January 2006, 09:48 AM   (permalink)
Assuming you want to prevent the massive distortion shown on your graph?, you need to add some kind of automatic gain control in the feedback path. This is commonly done using a special (expensive!) thermistor or a cheap incandescent light bulb. It can also be done using a FET circuit, or (crudely) with diode clipping.
If you google for 'wien bridge oscillator' you will find plenty of information and many circuits.
Old 9th January 2006, 11:10 AM   (permalink)
I think there is nothing wrong with my drawing. The output looks like that. BTW, the incandescent light you mean, any torchlight bulb will do? And I'm experimenting it with my own regulator ckt. check below..... :roll:
Old 9th January 2006, 12:13 PM   (permalink)
No, it has to be fairly specific, usually very low current bulbs are used.
I don't really see the relevance of that?, what is it supposed to do?, and where does it connect?. A wien bridge oscillator is a VERY old and common circuit, with many examples you can download off the internet, why not use a 'proper' method?.
Old 9th January 2006, 12:18 PM   (permalink)
I hate to point this out, but your waveform implies that time reverses periodically ? ??
spuffock is offline   Reply With Quote
Old 9th January 2006, 12:32 PM   (permalink)
I haven't used pins 4 and 8 of that particular amplifier.
It isn't normal for a waveform to go left when it is supposed to go right.
This should indicate that the oscillator isn't functioning correctly.
What kind of waveform are you trying to achieve?
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline   Reply With Quote
Old 9th January 2006, 02:30 PM   (permalink)
I need to build a cicuit to drive 2 motor. The speed of the 2nd motor dependent with the first motor. However I need to do some operation like comparator and etc. And to do this in analog domain I need AC signal, am I right? Then the oscillator is to serve that purpose. To drive motor, then I need to convert the AC signal into DC.
As for the bulb, how about this one? Is it OK?
Let me clarify the output, the output is like capacitor charging and discharging with +ve and -ve side execpt it kind of distort (maybe the gain to high).
don\'t flame me.....I\'m just newbie...
Old 9th January 2006, 02:53 PM   (permalink)
Your requirements are rather vague, but I wouldn't have thought so?.
This sounds even stranger?. Are you using normal DC permanent magnet motors?.
Possibly, but I (yet again) suggest you simply get a circuit off the internet, which will specify whatever gain system it uses. But as you're not wanting any quality (wien bridge oscillators are commonly used for very low distortion sinewaves), a simple diode clipping type circuit would be nmore than good enough.
Yes, because you've left out the most vital part of the circuit, the automatic gain control.
But, from what you've said, I don't see as you have any need for an oscillator at all?.
Old 9th January 2006, 04:24 PM   (permalink)
I have built this circuit and have found it to be more than good enough. I used polystyrene caps and ordinary resistors matched with a multimeter. It apparently uses a transistor as an AGC. That page explains a lot about how it works if nothing else, but I reccomend using the schematic so long as you don't need variable frequency.
http://home.att.net/~theremin1/Circu...scillator.html
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline   Reply With Quote
Old 9th January 2006, 07:10 PM   (permalink)
Texas Instruments has a pretty good applications note about many kinds of sine-wave oscillators. Their Wien bridge oscillator with a lightbulb for AGC has a serious error:
Old 9th January 2006, 07:28 PM   (permalink)
Your "regulator" is a wonderful circuit to short the output of your "oscillator".
When the output attempts to go more positive than 8.9V, both diodes conduct and short the output.
Old 9th January 2006, 07:54 PM   (permalink)
AG, that's a low-distortion, half-wave oscillator. :wink:
Ron
Roff is offline   Reply With Quote
Old 9th January 2006, 08:22 PM   (permalink)
[quote="Ron H"]
Excellent! :lol:
TI sell ICs. They want you to make two circuits for each oscillator, one for each half of the sine-wave.
Old 9th January 2006, 08:25 PM   (permalink)
[quote="audioguru"]
Excellent! :lol:
:lol: :lol: :lol:
Ron
