Old 8th January 2006, 08:30 PM   (permalink)
Default DC motor - PLC protection
I am running a PLC and a 2Kw 24V dc motor from the same acumulator. but when the motor starts the plc trips to stop. I believe the easiest way to over come this problem is to mount a capacitor but I cannot figure out the specs for it. how can ı calculate what my need is.or have any better ideas or any solutions other than this?
G.DEMIRURAL
demirural is offline
Old 8th January 2006, 09:42 PM   (permalink)
Default Re: DC motor - PLC protection
2Kw at 24V is 83 amps!, assuming that's running current?, then the start current could easily be a few hundred amps - how big (VERY BIG!) is your accumulator?.
A capacitor to try and provide the current required would be absolutely HUGE - a better way would be to diode isolate the supply to the PLC, and fit a large capacitor on the PLC, to keep that running for a while when the 24V drops way down!.
Old 8th January 2006, 09:58 PM   (permalink)
NOT only that but the capacitor will add its own in-rush current to the system which will compound the situation
Two option
1) in-line inductor to limit the current. This will effect dynamic performance
2) Since it is a startup problem, has a resistor in series with the DC-machine and after a set period (controlled by some other means) have a relay short out the resistor, thus bypassing it
Nothing is impossible.
Styx is offline
Old 10th January 2006, 11:52 AM   (permalink)
The acumulator is a 280 amp/hour array of 2V acumulators ( the ones that they use in tow trucks) I will try the series resistor which is some what easier to apply for me. I am still open to suggestions though.
G.DEMIRURAL
Old 10th January 2006, 11:55 AM   (permalink)
As I suggested before, diode isolate the power to the PLC, and hang a big capacitor on the PLC (which will keep the PLC powered when the batteries drop briefly).
Old 10th January 2006, 06:47 PM   (permalink)
I agree with that suggestion.
JimB is offline
