Old 28th December 2005, 09:14 PM   (permalink)
Default S-Video/RCA output to VGA monitor
I am trying to build converter from Video camera (S-Video or/and video out RCA) directly to computer monitor. Computer monitor has only VGA input. Does anyone know of a circuit on how to be able to do this? Any advice will be helpful.
Thanks in advance for all your help
Vlad
Vlady is offline
Old 29th December 2005, 09:05 AM   (permalink)
Default Re: S-Video/RCA output to VGA monitor
I suggest you buy one! - you're not talking about a trivial item, you've got to not only decode the composite signal to produce RGB, you've also got to digitise the signals, store them in memory, change the number of frames per second and lines per frame, and play them back out. All this has to be done in real time - commercially available ones will use custom chips to do it, you won't have that option!.
Old 29th December 2005, 01:35 PM   (permalink)
VGA interfacing is pretty easy and they make chips that will decode a composite signal but the true difficulty lies in the conversion process and deinterlacing. A dsPIC is fast enough to display static images or very simple hardware based sprites in 640x480 resolution at 60Hz but even at 40MIPS, you simply do not have the computational power to sample the input, store it in a frame buffer, deinterlace it, and then display it in real time.
The only efficient way of doing it without resorting to an ASIC is to use an FPGA. They can easily interface with high speed parallel interface ADCs and DACs and their structure allows for highly parallel designs which is critical in large data throughput applications like this.
phalanx is offline
Old 30th December 2005, 01:49 AM   (permalink)
I actually found a schemetic on how to buil on. Here is the attachment.
Vlady is offline
Old 30th December 2005, 10:38 AM   (permalink)
As you can see, it's pretty complicated, are you able to source all the components OK? - if so, what cost are you talking about? - compare that with buying a ready built one!.
This is also a fairly primative one, it looks to be simply doubling the line speed?.
Old 30th December 2005, 03:42 PM   (permalink)
This is not about buying one. This is all about building one yourself, a chalange.
Vlady is offline
Old 30th December 2005, 03:59 PM   (permalink)
Yikes! :shock:
This has to be one of the bigest schematics ive seen.
Il give you shocking experience.
Someone Electro is offline
Old 30th December 2005, 04:02 PM   (permalink)
So you're quite happy spending more, for an inferior result?.
Old 30th December 2005, 05:07 PM   (permalink)
I guess you can say that :wink: . If you look at it it is not that difficult or expensive to built. Yes it will be time consuming and most difficult part that I can see is to troupleshoot it
Vlady is offline
Old 30th December 2005, 05:16 PM   (permalink)
This circuit is designed for NTSC video. Is that what you need?
Ron (aka Rube)
Roff is online now
Old 30th December 2005, 11:23 PM   (permalink)
Hmm, a delayline, 1nF caps, plenty of other small values. Looks to me like this would be one pig of a PCB to layout and actually have work.
May be cheaper to get a multi-interface video card for your PC and be done with it.
Just my 2 cents.
zevon8 is offline
Old 9th August 2008, 02:28 AM   (permalink)
thank you
plz i want simple cicuit
ahmed_2040 is offline
Old 9th August 2008, 02:42 AM   (permalink)
Originally Posted by ahmed_2040 View Post
thank you
Ok here is one.
Forget injuries, never forget kindnesses.
Mikebits is offline
Old 9th August 2008, 01:57 PM   (permalink)
LOL!! "OMG it workz, thx!!"
Originally Posted by Mikebits View Post
Ok here is one.
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 9th August 2008, 02:27 PM   (permalink)
Ok here is one.
I would use a PIC or AVR... to light that lamp.!
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
