Hi, been a while... do any of you remember me? :P
Anyway, I was looking at this schematic... I know it's not complicated, but that's sorta what I want to do. I would need to modify it a bit. For one, I need it to be held high while the beam is undisturbed, and pull "Vout" to ground when interupted, instead. I also need to sextuple the circuit... I need six emitters, and 6 detectors, and I need to design it in such a way, to where if ONE on the six beams is interupted, it will pull ONE terminal to ground. Do I need to use OR gates for this? It's basically like a security system. If any one of the six beams is interupted, it pulls low, and triggers an alarm. 'Cept most security systems probably go high, but that's not the point. :P
Can anyone give me a circuit for this, or point me in the right direction to make one myself? Thanks.
Rain
P.S. Did you miss me? 8)
/ or use a phototrans pnp type
