Old 24th November 2005, 03:05 AM   (permalink)
Default pic low power problems
Hello!
I am having problems putting a pic 12f629 into low-power mode.
Before the sleep command the power consumption is 540ua and afterwards it is 47ua (so I think it is actually getting the sleep command. ) Sleep current should be 4ua...or am I misreading something?
I have nothing connected to any pins other then 3 volts + and - on vdd and vcc
I have written my code in pic simulator’s basic compiler. Following is the code.
TRISIO = %000000
Dim count2 As Word
count2 = 0
start:
GPIO = %111000
WaitMs 10
GPIO = %000111
WaitMs 10
If count2 > 20 Then  'should be 16000
count2 = 0
GPIO = %000000
WaitMs 5000
ASM:        sleep
Else
count2 = count2 + 1
Endif
Goto start
End
If you need to see the assembly code here it is:
; Begin
	R0L EQU 0x20
	R0H EQU 0x21
	R1L EQU 0x22
	R1H EQU 0x23
	R2L EQU 0x24
	R2H EQU 0x25
	R3L EQU 0x26
	R3H EQU 0x27
	R4L EQU 0x28
	R4H EQU 0x29
	R5L EQU 0x2A
	R5H EQU 0x2B
	ORG 0x0000
	BCF PCLATH,3
	BCF PCLATH,4
	GOTO L0002
	ORG 0x0004
	RETFIE
L0002:
; 1:  'INTCON.GPIE = 1  'enable b0 int.
; 2:  'INTCON.GIE = True  'enable all un-masked interrupts
; 3: TRISIO = %000000
	BSF STATUS,RP0
	CLRF 0x05
	BCF STATUS,RP0
; 4: Dim count2 As Word
;       The address of 'count2' is 0x2C
	count2 EQU 0x2C
; 5: count2 = 0
	CLRF 0x2C
	CLRF 0x2D
; 6:
; 7:
; 8: start:
L0001:
; 9: GPIO = %111000
	MOVLW 0x38
	MOVWF 0x05
; 10: WaitMs 10
	MOVLW 0x0A
	MOVWF R0L
	CLRF R0H
	CALL W001
; 11: GPIO = %000111
	MOVLW 0x07
	MOVWF 0x05
; 12: WaitMs 10
	MOVLW 0x0A
	MOVWF R0L
	CLRF R0H
	CALL W001
; 13:
; 14: If count2 > 20 Then 'should be 16000
	MOVF 0x2C,W
	MOVWF R0L
	MOVF 0x2D,W
	MOVWF R0H
	CLRF R1H
	MOVLW 0x14
	CALL C003
	BTFSS STATUS,Z
	GOTO L0003
; 15: count2 = 0
	CLRF 0x2C
	CLRF 0x2D
; 16: GPIO = %000000
	CLRF 0x05
; 17: WaitMs 5000
	MOVLW 0x88
	MOVWF R0L
	MOVLW 0x13
	MOVWF R0H
	CALL W001
; 18: ASM: sleep
	sleep
; 19: Else
	GOTO L0004
L0003:	MOVLW 0x1F
	ANDWF STATUS,F
; 20: count2 = count2 + 1
	MOVF 0x2C,W
	ADDLW 0x01
	MOVWF 0x2C
	MOVF 0x2D,W
	BTFSC STATUS,C
	ADDLW 0x01
	ADDLW 0x00
	MOVWF 0x2D
; 21: Endif
L0004:	MOVLW 0x1F
	ANDWF STATUS,F
; 22: Goto start
	GOTO L0001
; 23:
; 24:
; 25:
; 26:
; 27:
; 28:
; 29: End
L0005:	GOTO L0005
; 30:
; 31:  'On Interrupt
; 32:  'count2 = 0
; 33:
; 34:  'INTCON.GPIF = 0
; 35:  'Resume
; 36:
; 37:
; End of program
L0006:	GOTO L0006
; Comparison Routine
C001:	MOVWF R1L
	MOVLW 0x05
	GOTO C007
C002:	MOVWF R1L
	MOVLW 0x02
	GOTO C007
C003:	MOVWF R1L
	MOVLW 0x06
	GOTO C007
C004:	MOVWF R1L
	MOVLW 0x03
	GOTO C007
C005:	MOVWF R1L
	MOVLW 0x04
	GOTO C007
C006:	MOVWF R1L
	MOVLW 0x01
	GOTO C007
C007:	MOVWF R4L
	MOVF R1H,W
	SUBWF R0H,W
	BTFSS STATUS,Z
	GOTO C008
	MOVF R1L,W
	SUBWF R0L,W
C008:	MOVLW 0x04
	BTFSC STATUS,C
	MOVLW 0x01
	BTFSC STATUS,Z
	MOVLW 0x02
	ANDWF R4L,W
	BTFSS STATUS,Z
	MOVLW 0xFF
	RETURN
; Waitms Routine
W001:	MOVF R0L,F
	BTFSC STATUS,Z
	GOTO W002
	CALL W003
	DECF R0L,F
	NOP
	NOP
	NOP
	NOP
	NOP
	GOTO W001
W002:	MOVF R0H,F
	BTFSC STATUS,Z
	RETURN
	CALL W003
	DECF R0H,F
	DECF R0L,F
	GOTO W001
W003:	MOVLW 0x0C
	MOVWF R2H
W004:	DECFSZ R2H,F
	GOTO W004
	NOP
	NOP
	MOVLW 0x12
	MOVWF R1L
W005:	DECFSZ R1L,F
	GOTO W006
	CALL W007
	CALL W007
	NOP
	NOP
	RETURN
W006:	CALL W007
	GOTO W005
W007:	MOVLW 0x0D
	MOVWF R2L
W008:	DECFSZ R2L,F
	GOTO W008
	NOP
	RETURN
; End of listing
	END
I would greatly appreciate if you have any idea what is wrong, or if you know if my problem is hardware, or software related.
goodpickles is offline
Old 24th November 2005, 07:11 AM   (permalink)
Checkout the PIC12F629 datasheet. Each module's power consumption is listed on the DC characteristics page. You may have to turn OFF some of the modules to get the lowest power consumption. For example, BOD and the watchdog timer should be disabled in the configuration fuses. You don't need brown-out detection because that could wake the device out of sleep should the voltage drop below brown-out level. Same is true with the watchdog timer.
In addition, set all pins to input so none of them will source while sleeping.
This should have been posted under microcontrollers section.
"Having to do with Motion Control"
motion is offline
