hi i need help! i want to send data via a uhf voice tranciver(walkietolklie) with a low bitrate(i dont mind). so ineed some good ideas about that. i have a pair of uhf transceiver with a total bandwidth of 700khz and it is from 700khz to 1400khz. so i need to convert data to voice and then voice to data.plz help
| | #2 | |
For voice to data, rip out the speaker in the receiver and replace it with the Stereo VU meter found at talkingelectronics.com. For best results, make sure the reveiver recognizes the speed of the transmitter (multivibrator frequency), or you will lose characters.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | ||
thnx for that but my real problem is that i dont want to remove mic or speaker! i need to use it for sending data and voice and i dont want to recieve fake data if someone talks! So i need some kind of modulation or something! of course i dont want to send data and voice at the same time.
| | #4 | ||||
In other words, speaker should not be used as data input because it isn't reliable. It is better for voice input. Quote:
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |||||
man here is paint about! i know its hard! but plz give a try! i need those 2 boxes (audio2data mod & data2audio demmod)!!!!!!!!!!! thats what i need and if i get those 2 boxes i ll have both data and voice com!!! and i dont mind if i have a beeep on speaker when i send data! thnx a lot!!!
| | #6 |
It sounds like you are describing a modem - modulator/demodulator. Sometime between the time that dinosaurs ceased to roam the earth and the present time, computers were linked to each other via a telephone modem. You put the handset in the modem's cradle on each end and the modem converted the datastream into audio (modulate) and then at the other end it converted the audio into a datastream (demodulate). With your transceivers you'd be limited to one way communication however you could use two pairs for two way communication.
__________________ stevez | |
| | #7 |
stevez: It sounds like you are describing a modem - modulator/demodulator me: thnx for info stevez: Sometime between the time that dinosaurs ceased to roam the earth and the present time, computers were linked to each other via a telephone modem. You put the handset in the modem's cradle on each end and the modem converted the datastream into audio (modulate) and then at the other end it converted the audio into a datastream (demodulate). me: if i want a historical review ill to find it in an ather place stevez: With your transceivers you'd be limited to one way communication however you could use two pairs for two way communication me: pls take a look at that photo is it or not HD 2way com??? IN ONE PAIR??? IF SOMEONE HAVE A GOOD IDEA (electronic idea)ON HOW TO MAKE THOSE 2 BOXES (data to audio mod & audio 2 data dem) PLZ SHARE IT WITH ME!!!!!! | |
| | #8 | |
I suggest you try googling for "packet radio modem", which is what radio amateurs use for data communications, on specific allocated legel frequencies. | ||
| | #9 | ||
a microphone can be considered as a speaker, so your hand drawn diagram indicates to me that your microphone will function exactly the same as your speaker, because they are connected in series. Quote:
| | #10 |
"It's only one way at a time" i know that "pls take a look at that photo is it or not HD 2way com" the HD=half dublex BUT I REALY THANK YOU FOR "packet radio modem"!!!!!!!!! THANK YOU SO MUCH I FOUND WHAT I WAS LOOKING FOR!!!! THANKS AGAIN!!!!!!! FOR MY NEXT QUESTION I'LL PM YOU FIRST! | |
| | #11 | ||
__________________ Uncle $crooge | |||
| | #12 | |||
Like most of the answers msecha writes everyone needs to be corrected. Looks like he should get off the organic smokes and go back to school well pre-school should be a good start
__________________ " The only way to avoid human error is to avoid the use of humans" | ||||
| | #13 |
Many of us Ham Radio Operators were treated to a new digital mode invented by a gentleman in the UK several years ago called PSK31... It's very narrow bandwidth provides an excellent signal-to-noise ratio and many of us have acheived some very nice low power/weak signal contacts with it... Best of all, it utilizes the DSP capabilities of the sound card in your PC and connects easily from the sound card to the audio connectors on our transceivers... It also works quite well from PC to PC simply using speakers and mics' on both PCs (grin)... Try googling PSK31 and download one of the many free PSK31 programs... Have fun... Regards, Mike | |
| | #14 |
normally I don't answer completely wrong, but this time I did, because his ground symbol was not a standard one, and his circuit looked like he drew it in 10 seconds. When I was answering, I missed the ground symbol.
| | #15 |
Hi MStechca, You're forgiven this time. :lol:
| data, send, uhf |
