my teacher at school wanted the class to desine a circuit that uses a 555 timer, so the first thing i said was smoke bomb. but he said it has to ocilate. so i thought jacobs ladder. if it ocillates at 50Hz and feed 4 transformers out of wall warts backwards, i will have a very high voltage.
any comments, suggestions. ps: i don't want to use a neon sign transformer or a tv flyback.
when you post that reply, im just kidding. |
When you connect step-up transformers so the 2nd one steps-up the output of the 1st one, then the 2nd one is such a heavy load on the 1st one that they don't work.
To make a high voltage you need a transformer that is designed for it. It also needs to have special high voltage insulation that isn't in a wall-wart. If you connect a transformer backwards to the mains, you won't get the mains voltage stepped-up, you'll get smoke and maybe a fire.
Uncle $crooge |
You also don't have a prayer that such a project would be acceptable in school 8)
i have done this before i worked ok for me.
school don't care, i have a teacher that will let me do almost anything
But at abut 2kV the secundary will start to arc.
You need an TV flyback or an neon transformer.
i do have a tv flyback transformer but don't know how to use it. it sould generate 35kv.
what about a massif inductor
In the old days they used inductors but you wod need afuly a lot of wire.
Flyback transformers work at ultrasonic freq.(more then 20KHz)You need an transistor to drive it. Anyway i never made an jacobs lader.
how do i get 20Kh i can't think of a power transistor that can switch that fast?
well, i don't mean like that. he's a nice guy, stics to the rules but i think i am pushing. there are alot of teachers like that in our school even the deputy head. but the exam grades are almost perfect, in drama last years gcse class all got a C or above and in science somone got 100% on a test!
You could use the 555 to drive the flyback tranformer from 12v. I think that's the input to them?
You will probably have to find a really old flyback transformer because the new ones have a protection diode built into them that is impossible to remove and makes it hard to make a jacobs ladder. The older ones diode is really easy to remove.
I'm no electronics god, i just talk too much. |
what makes it so hard?
