Old 6th November 2005, 07:27 PM   (permalink)
Experienced Member
oliverb is on a distinguished road
Default DIY Temperature Compensated Crystal Oscillators TCXO
I am building a digital master clock using a 32.768Mhz quartz crystal.
I am thinking about temperature controlling it using an old LCD temp module. Embeding the crystal. rc network and temp probe in a small block of hardwood with a heating element.
This is the problem what do I use as the heater?
I think it would be best run a few degrees warmer than room temp so would a resister work?
I could embed the control transistor in with the resistor heater as well.
Any advice or thoughts appreciated.
Brett.
oliverb is offline   Reply With Quote
Old 6th November 2005, 08:04 PM   (permalink)
Experienced Member
Mike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to all
Hi Oliver,
I wonder what kind of stability you're lookin' for from that project Sir?
There's a pretty nice little 1-inch by 1-inch circuit board here; http://www.aade.com/dfd3.htm for $15 USD that includes a 10-MHz 1-ppm TCXO and the little trimmer pot', and he even sets the frequency against his rubidium reference before shipping it to you...
Good luck on your project... Regards, Mike
Old 6th November 2005, 09:16 PM   (permalink)
Experienced Member
Originally Posted by Mike, K8LH
Hi Oliver,
Thanks for the info.
1 ppm would be great!
However, I would like to try and build it myself as I have most of the parts from old projects.
Brett.
