hi, i have done a circuit with a 9v battery, a buzzer, an LDR and 2 transistors, when there is no light i want the buzzer to sound, i am using a lazer on one wall and an LDR on another and when the beam is broken, i want the buzzer to sound can you see anything wrong with this circuit?
Thanks, Mike |
oops sorry, the circuit shows an LED not a buzzer but i plan to use a buzzer
uhh...
This cirucit dosnet seem to be very functional to me.
Here is how to turn-on a transistor or darlington-connected pair. Match R1 to the value of your LDR. The little 9V battery won't last very long if the LDR and R1 are low resistance or if the LED or buzzer are continuously activated.
Uncle $crooge |
The R1 determins the sensetivety of it.
If its low resiatance then the bzer will start even in dim light if its high then the buzer will need to be im a darker place to start.
done it, it works, Thanks
Horray! :lol: :lol:
Uncle $crooge |
LOL :lol:
We at electroetch garante it to work.
worked a carm, set it up, leftt my room untidy, went out and my mum opened the door slightly BZZZZZZZZZZZZZZZZZZZZZZZZZZ she shut it and wouldnt go in again!!!!! :lol:
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
mine only work on breadboard, when i solder them, they never seem to work, i check all the tracks and nothing is touching things they shouldnt be, so i give up on them!!!
but, i have got ONE project to work, an adjustable LED flasher using a 555 |
1) Look at whether the emitter and collector of the transistors are reversed. A good pic of the pins of a transistor is shown in its datasheet. 2) Maybe your soldering iron is too hot or too dirty. My temperature-controlled soldering iron tip is cleaned by a quick wipe on a damp sponge then makes a perfect solder joint in 1 second. 3) Use rosin-cored solder. :lol:
Uncle $crooge |
i mean soldering circuits with no transistors, just diodes (which i checked and are the right way round), resistors, switches, a 555 etc
