At present we have only static solar panels to get energy. this will only track energy from the sun only at one position. so if there is some thing called as a traking system to track the sunlight. it will be very much better to get enery all through the day by tracking he sunlight.
by this method we can get a good amount of power but there some constraints to be faced. some are like, the power needed to drive the tracking system, cost of the panels. can u suggest me an idea. can any one guide me or give your suggestions. my email id is pmrakeshkumar@yahoo.com [/code] |
If you have a solar concentrator (a big lens or reflector in front of the panel), there is a much greater need for tracking. What you need to consider is if the cost of the tracking system would not be better spent just buying a panel 35% larger or a higher output cell technology, which has no maintenance issues like stuck motors and is much simpler.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
As long as the panel is not in shade you also get an output if the sun shines on it obliquely. Its just a little less output than if the panel were tracking the sun. The complexity of a tracking system makes its benefits questionable for all but rather large arrays. You could also try amorphous solar panels which are more shade tolerant, they give a reasonable output even on overcast days. Klaus |
i've seen some trackers that work off liquid in a tube an tracks by covection on a set ;path check out some of the solar stores on the net
