good day to all!!!
anybody there knows how to design a calculator???? my project here is to design a 2 seven segment display LED using a hexadecimal matrix design...the problem is i dont know how...the design should have a primary encoder to determine which number will appear if u happen to pressed 2 keys....then i need to design a 2 memory segment for the 2 seven segment display...........and the design must be all in LOGIC CIRCUITS......THE SIMPLEST DESIGN THE BETTER THANKS |
I think the easiest way to design a calculator is to buy a calculator!!
Myself, I've often wondered about that. It should use so many chips and so many memory elements: adders, integrators...My God! So that put me off. These chips might even be difficult to find and if you should opt for discrete components, I wouldn't tell you you're going to end up with a ridiculously complicated & bulky circuit. Hey, that's just my idea. Luckily someone would guide you to a schematc. :wink:
Everybody can but not everybody will. |
Simple use an microcontroler.So you allredy have your computer all you need to add is the human machine interface(Display and keys)
Just stuck on an matrix keypad and an 7 segment or even an LCD. PIC MCUs from microchip cost from $1 to $20 (depends what kind of it it is) You can get them fro free too trough the samples servise.
how many functions? add, subtract, multiply, divide, power, percent, log, ln, rooth....
venture into the realm of DIY discrete calaculators. http://www.cs.ubc.ca/~hilpert/eec/ca...skTechSum.html and for the truly fearless, schematics for the Apollo guidance computer can also be found on web.
It may seem like a good idea at the time but.. never stir your cold coffee with a soldering iron. |
