Dear Friends,
The transformer of my power supply (which I used for 4-5 years) has given away recently. Current rating 1.5 A Ripple less than 0.1% 5 Volts dual rail well regulated/balanced output 12 Volts dual rail well regulated/balanced output Variable regulated output say from 1.25V to 24Volts (single rail) (I know I can use LM337,317 or 350) Digital voltmeter/ammeter. Ckt for blown fuse indicator. I wanted to use IC regulators with minimum number of transistors. In my country it is difficult to obtain 2N...type transistors and multi secondary power transformers. (However, I have some 2N3055 pwr. Trs. in hand) If you can help me to find a suitable ckt in internet or if you have any, please contact me through this page or you may directly e-mail to me on ravi@ualink.lk Thanks & regards Ravi |
With all that specifications, your Bill of Materials will burn a hole in your pocket. Instead you can buy a ready made dual tracking power supply which will cost you much less than making one yourself.
"There is no way to peace, peace is the way!" |
I know I will have to spent lot of money. In that case I may take out the digital meter and go for a normal analog meter. However, electronic hobby is an expensive game. Thanks.
Ok, here are some schematics. You'll have to make some modifications according to your needs.
http://www.sas.org/E-Bulletin/2001-1...ro/column.html http://sound.westhost.com/project44.htm
I've seen several power supply projects where a low cost DVM was used as a panel meter - more or less glued on to the front of the chassis. Watch the sales and they can be had for $10 to $15 here in US - which is about the cost of a panel meter.
stevez |
