You have not specified the output voltage that u require.
U need a step down transformers,two capacitors(one across the rectifier and the other across the IC that u will use for the desired output voltage).U will also need a bridge rectifier at the output of the transformer.The capacitors will do the required filtering.
Just try it out.
Byeeeee,
Peeyush
