The LEDs won't do anything with the diodes in parallel with them. Therefore the 1st transistor doesn't do anything.
Uncle $crooge |
First off, why don't they do anything?
Second off, someone that built my pedal (I posted the schematic on diystompboxes.com) had said the same thing, but then tried it and noticed a difference when using both trannys. here is the link: http://www.elixant.com/~stompbox/smf...?topic=40831.0
Life is what you make it. |
The LEDs won't do anything with diodes in parallel with them.
The sim looks like an ordinary "soft clipper":
Uncle $crooge |
Well, first of all, you changed the schematic.
It uses MPSA13s, which are darlington trannys, unlike 2n3904s. Also, Q1 doesn't feed into Q2 like you show, both bases are connected to input line only. They are running in parallel.
(permalink) | ||
An LED needs 1.8V or more to function. The ordinary diodes in parallel with them limits the voltage to 600mV so the LEDs do nothing. Your circuit has a symmetrical clipped waveform, therefore doesn't produce even harmonics. The Hendricks circuit I posted has an unsymmetrical waveform, therefore produces all harmonics.
Uncle $crooge |
nm, I would have known that if I thought about it lol. I still don't know why, but for some reason it effects the guitar's sound using one on tranny or both...
The small capacitance of the 2nd darlington might cut the high frequencies a little. So would a small capacitor.
The LEDs didn't light, right?
Uncle $crooge |
Correct, no light from the LEDs. And you may be right. I'll have to play with it some more when I get the chance.
**edit** What do you think would happen using one 1n914 and one LED for diodes on a single MPSA13 circuit?
Uncle $crooge |
you mean according to which direction the LED is facing?
Uncle $crooge |
The LEDs probably won't emit enough light to see, since you are only driving microamps into them.
With the bazzfuss circuit the LED emits enough light (when playing it goes along with how hard you are playing).
http://home-wrecker.com/bazz.html
Audioguru (and anyone else), I made a symbol for an NPN Darlington for SwitcherCAD. Copy the code below into a file called npndarlington.asy and save it in C:\Program Files\LTC\SwCADIII\lib\sym\Misc.
Version 4 SymbolType BLOCK LINE Normal -16 0 0 0 LINE Normal 0 32 0 -32 LINE Normal 64 -48 0 -16 LINE Normal 64 48 0 16 LINE Normal 48 32 64 48 LINE Normal 42 44 48 32 LINE Normal 64 48 42 44 LINE Normal 64 48 80 48 LINE Normal 80 80 80 16 LINE Normal 144 0 80 32 LINE Normal 144 96 80 64 LINE Normal 128 80 144 96 LINE Normal 122 92 128 80 LINE Normal 144 96 122 92 LINE Normal 144 -48 64 -48 LINE Normal 144 0 144 -48 SYMATTR Prefix X SYMATTR Description NPN Darlington PIN 144 -48 NONE 8 PINATTR PinName C PINATTR SpiceOrder 1 PIN -16 0 NONE 8 PINATTR PinName B PINATTR SpiceOrder 2 PIN 144 96 NONE 8 PINATTR PinName E PINATTR SpiceOrder 3 Code:
*Si 625mW 30V 500mA pkg:TO-92B 1,2,3 .SUBCKT MPSA13 1 2 3 Q1 1 2 4 QMOD .1 Q2 1 4 3 QMOD .MODEL QMOD NPN (IS=360F NF=1 BF=337 VAF=98.6 IKF=.5 ISE=637F NE=2 + BR=4 NR=1 VAR=40 IKR=.75 RE=3.5 RB=14 RC=1.4 XTB=1.5 + CJE=133P VJE=.74 MJE=.45 CJC=14.1P VJC=1.1 MJC=.24 TF=1.27323N TR=17.4N) .ENDS MPSA13 Place the NPN darlington symbol on the schematic, right-click on it, and enter "mpsa13" in the SpiceModel line. You might want to make this visible. |
I would not want to play my very low distortion stereo through one of those circuits. :cry: The fuzz term, "octave-doubler" describes even harmonics since the 2nd harmonic is one octave above the original, then the 4th harmonic is another octave above.
Uncle $crooge |
