I'm having a lot of grade trouble in my EE major, so I don't get to build much anymore. Actually, I've been thinking of giving up on my degree. :cry: There aren't a lot of parts though, so I guess I could do it as long as I can get the coils right. When it says the coils are [.27-.3], that's in millihenrys right?
How would i use a pic and a transmitter chip from LINX??
is that the easiest way to do this?? I,unlike digitan, am most intrested in building the simplest, cheapest wireless transmitter possible. I only need it to go a couple of feet and allow me to send files back and forth with a pair of TI calculators. |
hi arigold
Try looking at www.rentron.com for some good ideas. |
ok but i dont have much experience doing this sort of stuff, so i really need something that is fully planned out
The posted schematic might not have that problem, but since it doesn't amplify the recieved signal, I doubt it can sink enough current for the TI calc to read. I was hoping Nigel, audio or the others could recommend something; but so far I've gotten more questions than answers. |
Someone mentioned radiotronics parts in another topic, they were low cost ($4 each I think they said), you can make your own antenna (rather than buy one). Maybe hit the radiotronix website and see what they have. Is the output from the TI RS232 TTL levels? I will have to go back and read the posts again. |
The outputs and input for TIs are at TTL levels, and each use 1 bipolar transistor for logic switching. For inputs, they use diodes and pull up resistors to read the current state of the lines. The more detailed description is on Ticalc's Technical Information Archive titled "All about the 86 Link Port." (I couldn't direct-link).
Anyway, the diodes are why I wanted to ask audio and Nigel about the reciever. I'm pretty sure a crystal radio couldn't draw enough current through the diodes to switch the inputs from high (idle) to low. But if no one wants to help, I say screw 'em all; maybe some CW transeiver circuits would do the job. It's just a real pain encoding for 2 bi-directional lines at once. It would have to be done without a duplexer as well. |
Basically, as I said before, you need to build it and try - no good asking here, as no one has built it. |
I finally found this-
http://renaud.cerrato.free.fr/old/PIC92.htm I'd rather not have to build it though. If anyone is willing to build it for me please email me with a price quote of how much over the cost of the parts you would be willing to build it for. Schmidtzen (att) Gmail(dot) com |
That's pretty cool. I was suspecting using the same frequency for transmission and receiving would cause collision problems.
LINX's newer LR series can handle data rates up to 10000bps.
