Old 18th April 2005, 03:47 PM   (permalink)
Default PC controlled of/off LED
my project using 500 LED :idea: , need to switch them on/off individually using PC/laptop. :shock: please help
modelgraphix is offline
Old 18th April 2005, 08:45 PM   (permalink)
Default reply
Build this and make a series of LEDs of about a 100 each.
This website just shows hot to make 1 input but you could add more easily.
http://www.electronic-circuits-diagr...tersckt1.shtml
Robotics is heaven in my book.
Roboticinfo is offline
Old 24th April 2005, 06:59 AM   (permalink)
Here's the easiest way (I think):
Make a matrix (24 by 24 = 576 LEDs). Then, say LED #10 should be turned ON. If it's located on "input" 2 and "output" 5, then make "input" 2 High and "output" 5 Low. Keep other "outputs" high and other inputs "low".
You'll need to use 6 8-bit multiplexers (3 for "input" and 3 for "output"). Their addresses will be controlled to the PC parallel Port, so you'll need:
3 outputs for address selection on "inputs"
3 outputs for address selection on "outputs"
2 outputs for chip selection on "input" (1 out of 3 chips should be selected)
2 outputs for chip selection on "output"
After that, you can connect (in parallel) the corresponding address selection pins on 3 "input" and "output" multiplexers. The chip selection will tell to multiplexers which one the PC is controlling.
The LEDs should have their + connected to "input" multiplexers and - to "output" multiplexers. The Input of each multiplexer should be tied to Vcc.
Good Luck,
TI|CP
theimperia is offline
Old 6th June 2005, 07:50 AM   (permalink)
Default Re: PC controlled of/off LED
U may use a relay that connected to parallel port (D0-D7) to ON/OFF the LEDS. Get some info from http://www.geocities.com/bagtool/parallel_basic.html
free 8)
free1 is offline
Old 6th June 2005, 08:42 AM   (permalink)
free 8)
Relay? that would be expensive and slow...
"I share, thus I am"
Jay.slovak
Read this!
ICD2 Clone
Best PIC/DsPIC Bootloader
Read my Inchworm ICD2 review!
Jay.slovak is offline
