Hey, I'm attempting to build a high frequency variable oscillator on a range of 18 MHz to 48 MHz(preferably 48, but 42 would work if 48 is too high) using the 4011 quad NAND. I want it to work on the circuit that I'm posting, and I just need the values for C1, R1(pot), and R2(pot). Id like it if only one of the resistors was a Potentiometer, but if it cant cover the entire range, I would use 2. Can anybody help me out?
I mean, this cct can work up to 10..15MHz only. For higher frequencies build one with BJT or FET.
Sebi, How did you make a 4011 oscillator go so high? With only 27pF and both resistors 1K with a 12V supply mine barely reached 2MHz. I have heard that a 4049 high current buffer can reach 6MHz without the input resistor. Do I dare try using a 74HC00 high-speed Cmos IC for 15MHz or do you think it might melt?
Anybody have a circuit that could reach that range? Or even if I could hit 1MHz-5MHz, and multiply by 12. Anybody have any ideas? All I have to do is stay under $10(preferably $5). | |
The VCO of a 74HC4046 can go up to 17MHz. http://www.semiconductors.philips.co...046A_CNV_2.pdf
| | #6 |
I need much MUCH higher.
| | #7 | |
| | #8 |
This cct can work safely on 10MHz, but need 15V supply. Some good pieces work up to 15MHz. I strongly recommend the MC1648 for wideband tuning.
| | #9 |
Once again, I need much higher. I need to hit a controlled range of variable 18-48MHz.
| | #10 |
With C3=250Pf, the frequency is 20 mHz. With C3=10pF, the frequency is 45 mHz. A tuning capacitor from an AM radio would probably have that range.
| | #11 |
Thank you, thank you, THANK YOU SO MUCH! What are V1 and L1? | |
| | #12 |
Thank you, thank you, THANK YOU SO MUCH! OOPS: Double post. Could a MOD please delete this post. | |
| | #13 |
V1 is the 5 volt power supply but supply voltage is not critical. L1 is 7 turns #20 enameled wire on a 1/4 inch form (a standard pencil will do). The turns should be close and don't forget that the leads are part of the inductor, so keep them short.
| | #14 |
OK. Thanks. I have changed the pic a bit. Would this still work? Also, what is the difference between the 2 outputs? Could Q1 be substituted for any other transistor? Why does L1 say 275nH (what does it mean)? Did I mention, "Thank You"? | |
| | #15 |
I had used this circuit as a crystal checker (substitute the crystal for L1, C3 & C4). Out_2 was a 50 ohm drive to my frequency counter. 275 nano-henries is 275*10^-9 henries. Any transistor with Ft greater than 100 mHz should work, eg: 2N3904.
| frequency, high, oscillator, variable |
