| i need a basic power amplifier capable of supplying 600watts at 6ohm i dont mind if it is mono or stereo all help appreciated | |
Also, 600W is a VERY high power amplifier, it would cost a LOT to build one, and requires considerable experience and skill. A slight mistake in construction (and I do mean SLIGHT!) could easily destroy all the expensive components. | ||
| i have woofers that are defiently 6ohm but the tweeters are 8ohm 600watt is need although it could be on six channels of 100watt | |
You've stated a number of conflicting options, firstly wanting a 600W amp, then saying stereo would be OK, then that six channels would be OK - you need to clarify what you have, and what you are wanting to do!. As I said above, 6 ohm would be very unusual (but not totally unknown), but it is unusual for 6 ohm speakers to be available - they are mostly used in low cost audio gear, to try and push a little higher output spec. Are they actually labelled 6 ohms?, and what power rating do they have? (and what is it actually rated in?). For amplifier projects, you might look at http://www.ampslab.com/projects.htm for some interesting looking ones. | ||
| the speakers i have are; two 100watt 6.5ohm pioneer four 70watt 6ohm sony two 100watt 8ohm sony two sets of tweeters made of four 5watt 8ohm sony the use of the amp is for a friends band with the basic requirement of getting as much noise(of decent quality)from the speakers that ive got with out destroying them only one stereo input is needed it only needs onevolume control. :evil: | |
| and reasonably cheap | |
| new my speaker collection would have cost about £250-£300 but i got them mint condision about £30-£40 arfer having a quick look on the net the cheapest 600watt or 300watt pair is about £350 +the price of the amp would be to much so can we just go with ive got six 100watt 8ohm pa speakers and i need a 600watt amp | |
You certainly don't want anywhere near 600W to feed them, their printed ratings are probably at least double their real ones - I wouldn't like to try and put more than 100-200W through them, and I don't know if they would survive that either!. As well you have the problems of connecting that unusual number of speakers together and maintaining a sensible impedance. You also have the problems of volume, PA speakers are designed for high volumes and high powers, HiFi speakers are generally designed for relatively low volume and moderate power - they sacrifice efficiency to give better bass response from a smaller driver and cabinet - which is why HiFi amps are often very high power. The link I posted previously has designs for various high power amplifiers, any of those should be suitable for what you want, but don't be surprised if the speakers all die 8) | ||
| Just an extra thought!. Have you considered buying a ready built power module, and building your own casing for it?. It's probably cheaper (and certainly more likely to work) than building your own. Have a look at the amplifier modules at http://www.bkelec.com/ - their 300W one is only £84.75 inc VAT, or a 200W one is only £67.35 inc. These include the power supply and heatsinks - just wire it and go!. A frind of mine bought a load of them for PA years back, they sounded great and were reliable. | |
| Just connect all those speakers in parallel. Then the amp won't survive either. In series they will sound like crap. Boom, boom, no damping at their resonance.
| all of them are connected in parllel my sony home cinema 2nd hand has not broken in a year of non stop music it goes 2 poud for my family but i find it very quiet. | |
If you've paralleled the eight speakers you listed that gives a combined impedance of just under 1 ohm - this would almost certainly kill almost all amplifiers (unless the volume was kept very low?). So I'm presuming you've connected six speakers to the six channels of a Dolby 5.1 system?, which is quite correct. If you've paralleled the two 8 ohm Sony speakers, that will give 4 ohms, and again should be fine - most theatre systems are pretty cheap things, and usually feed 4 ohms (often based on cheap car radio amplifers). You might like to have a look at http://www.colomar.com/Shavano/speaker.html which gives helpful advice on PA speakers - the entire site is very useful!. I don't mean to try and 'put you down' at all, but you don't appear to have the slightest idea about what you're trying to do, I don't think you've got the slightest chance of building a high power PA amplifier at your current level of experience (it's not a project for beginners!). If you wish to get experienced at electronics, start with simple project and work up - starting at the top will only frustrate you when things don't work, and all your expensive parts destroy themselves. | ||
| Hi Monk, With speakers connected in parallel their impedance as seen by the amplifier is very low. If you turn up the volume to near maximum output then the current might far exceed the amp's spec. If the amp's circuit doesn't limit the excessive current then the amp will be destroyed. Read its spec for minimum allowed speaker impedance. Maybe 4 ohms which is only two 8-ohm speakers in parallel.
| it is a sony str-de315 it is dolby 5.1 but i only use stereo mode for simplicity from specs of the net 100w+100w @ 8ohms or 145w+145w@ 4ohms as for volume usually about 4 or 5 out of 10 | |
