Hi, I'm new to this board but not to the 'Net.
I have been working desultorily on a Cuk converter design for a while, and I have done a design based on the Bill Behen design laminate. I have a pretty workable set of Ls and Cs, and picked out a suitable N-Channel power MOSFET and a good Schottkey diode. I have damped both of my tantalum-film 'lytics with nice big cans and series resistances, and everything looks great.
Now comes the rub. I had originally thought that I could use a particular Maxim chip to drive it; unfortunately, I apparently had a brain anomaly and it won't work (luckily I only blew up one MOSFET finding that out). I tried to make a PWM using a TL084 biFET op-amp with a relaxation oscillator, integrator, triangle-to-pulse converter, and comparator, but I can only get about 20kHz before the waveform goes to crud, and that's not enough for my design.
I've been looking for several days, and have yet to come across a really good looking substitute PWM or other type of controller. The big problem is that everyone wants to make custom ICs for computer power supplies, and nobody has been paying attention to Maxwell's theory and understands why Behen is right, and the Cuk/boostbuck is optimal. (It really is, particularly from an RFI/EMI standpoint- which is important for my application, I am doing CCD astrophotography. Obviously, Behen has me totally convinced) If I just wanted 5V, I'd be all set, but this is a 12V supply for my telescope equipment, and I need 10A, and serious quiet. And I need something that will control the switch on a Cuk converter; yes, I'm pretty set on it being a Cuk converter, Behen has infected me and I also have Cuk and Middlebrook's Advances in Switched-Mode Power Conversion, both volumes. (All three- whatever, I guess they made the first two into a single one when they released the third one).
I have a leftover Maxim non-inverting gate drive chip, too, and it's all wired in. I'm ready to rock-n-roll if I just had a good source of voltage-controlled duty cycle to run the switch with, at like maybe 100 kHz or so. One other parameter to consider: I've found that big lead-acid batteries "glitch" every so often, and it's a real problem when you're trying to take a half-hour exposure and you don't find out until the end. What I want this thing to do is handle the 13.6 standard battery output and give me 12V, and keep giving me 12V come heck or high water until Vin goes down to, say, 11V or maybe even 9V (yes, yes, I know it will trash the battery, but I can always buy another one whereas a really clear night with excellent seeing is beyond price). I can do my own shutdown circuit if I have to; but of course the ideal controller would take care of all that for me.
So my question is, does anybody know of a really good controller for that? I've been looking at the UC2841 and UCC35702, and eyeing the MAX1651, which I think might actually work, but I would like to know if anyone out there has done this research before me and I am re-inventing the wheel.
Thanks in advance!
-Da Schneib
