Old 11th March 2005, 02:08 AM   #1
Default need a gated or triggered circuit ?
I need to make a circuit that inputs two signals one sine wave approx 100 hz and a posistive pulsed signal 10 to 50 hz and outputs the sine wave only during the on time of the pulsed signal with off time period same as the pulsed signals off time.
The frequencies may be different but will be in the low frequencies range.
If you can give me an idea using ICs from the 1970s-1980s as I have quite a collection of these.
Thank you
Doug
Doug is offline
Old 11th March 2005, 02:16 AM   #2
Voltages?
FRIED is offline
Old 11th March 2005, 03:32 AM   #3
Sorry ..
Most cases under 5vpp,,I can use a voltage divider if over 5vvpp.
Doug
Doug is offline
Old 11th March 2005, 03:53 AM   #4
I can't remember whether the 4016 analogue switch was produced then, but that's the obvious thing to use.
David Bridgen is offline
Old 11th March 2005, 04:04 AM   #5
An updated version of the 4016 is the 4066, it has a lower on resistance. Either one should work fine with the pulse signal as the control signal.
k7elp60 is offline
Old 12th March 2005, 03:09 AM   #6
I bread boarded the 4066 today and looks as it will do the trick.
again
Doug
Doug is offline
Old 12th March 2005, 10:07 AM   #7
You can parallel the switches for lower Ron if necessary
FRIED is offline
circuit, gated, triggered
