Old 25th February 2005, 08:43 AM   (permalink)
Default reply to vco design
thanx a lot for the detail.connecting to the breadboard wont give any problems,i hope.and hope that its not too large a circuit for the board i have,will tell you about the results.how do i show the output on an oscilloscope now?i just want to see if it produces oscillations,and that its sinusoidal?
bere is offline
bere is offline
Old 25th February 2005, 09:07 AM   (permalink)
You shouldn't attempt to build RF circuits on breadboard, it's the worst possible method you could try to use. It's very likely the breadboard will prevent the circuit working, particularly at 60MHz.
The output of the oscillator WILL be a sinewave, the ringing action of the tuned circuit guarantees it - massively overdriving it 'might' possibly manage a squarewave?, but it's unlikely.
Old 25th February 2005, 01:10 PM   (permalink)
You don't want to be trying to build RF designs on breadboard, certainly not at 60MHz!.
I agree
FRIED is offline
Old 25th February 2005, 04:45 PM   (permalink)
Back in the days before Protoboards (which I think are what you are referring to as breadboards), I used to "breadboard" high frequency circuits on single-sided copper clad. I laid out the circuit on 0.1" grid vellum, drilled all necessary holes, then cut pads with an annular cutter called a Roto-Bor. Later I used Vector pad cutters, which you could (and probably still can) buy with or without a handle. The one without the handle worked well in a drill press if you had one that would run at low speed. It had a tendency to occasionally pull the pad off the board. I see that they are now charging over $60 US for them. What a ripoff!
I have bought (at Fry's) double-sided material with plated-through holes on a 0.1" grid, with ground plane on one side. A couple years ago it was about $120 for about 1 sq ft, but you can cut it up and make a lot of little circuits, so I think it's worth it.
Roff is offline
Old 7th March 2005, 06:16 AM   (permalink)
Default reply to my vco design
would you kindly help me in identifying some components i want to use for my phase locked loop.i want a phase comparator,a crystal and frequency divider.what are the different types that are there?
bere is offline
Old 7th March 2005, 10:15 AM   (permalink)
Default A problem no...
but perhaps several of them...
Why not using perfboard? With little planning you can go away reasonably well, I think.
Agustín Tomás
atferrari is online now
Old 8th March 2005, 08:06 AM   (permalink)
hie.i have got almost all the components now but could you help me with part numbers for commonly found phase comparators and frequency dividers.i have a 10mhz crystal,that means i need a divide by 6.
bere is offline
Old 9th March 2005, 09:58 AM   (permalink)
Default help
how can you change a colpitts to act as a vco?where would you incorporate a varactor diode?
bere is offline
